DAN Cases A4-SFX arrives on Kickstarter
Published: 30th May 2016 | Source: Kickstarter |
DAN Cases A4-SFX case has arrived on Kickstarter, giving the world it's smallest Gaming PC case that is still suitable for almost any GPU.
What this case does is allow gamers to use some of the most powerful hardware while maintaining a form factor that is smaller than a backpack, making a Lan ready ITX PC as small as is feasible. This case supports SFX and SFX-L power supplies, MITX motherboards and dual slot GPUs tat are up to 295mm in length, making this PC suitable for a system containing an i7 6700K and a GTX 1080, which is quite a lot of power to contain in such a small enclosure.
This case was designed by Dan Cases but built by Lian Li, giving this case a premium look and feel and allowing the case side panels to be secured using Liam Li's push pin method.
This case will weight 1.25Kg and will be available with an anodised Silver or black exterior and a painted black interior. Full specifications are below.
Specifications
- Case Dimensions (H x W x D): 200 x 112 x 317mm, 7.25L
- Overall Dimensions: 205 x 112 x 327mm (including feet and rear protrusions)
- Weight: 1.25 Kg
- Graphics card support: Dual-Slot up to 295mm length
- Motherboard support: Mini-ITX
- Power Supply support: SFX, SFX-L
- Drives: 3 x 2.5" HDD/SSD
- Front ports: 1 x USB 3.0 (internal 20pin plug)
- Power button: Premium-grade button
- Material: 1.5mm aluminum, brushed exterior
- Side Panels: Easily clippable with Lian Li Push Pin technology
- Colors: Anodized black or silver exterior, matte black painted interior
- PCIe Extender: Includes the 3M Twin Axial 300mm PCIe Gen3+ extender, Link: 3M product page
CPU Coolers :Max. height 48mm
Hard Disk Drives: 2 x 2.5" HDD/SSD in drive bay: max. height 15mm + 1 x 2.5" HDD/SSD in front-area: max. height 9mm
On the Kickstarter page, this new case is available from €230, with only around 1500 Dan Case A4-SFX cases being available via the case's Kickstarter campaign.
You can view the DAN Case A4-SFX on Kickstarter here.
You can join the discussion on DAN Case's A4-SFX MITX PC case on the OC3D Forums.
DAN Cases A4-SFX case has arrived on Kickstarter. https://t.co/TflvannrOu pic.twitter.com/CeNB1Wt10Z
— OC3D (@OC3D) May 30, 2016
I'd have one if I had the money for it, best small form factor design I've seen in a while!Quote
