Danger Den release 295 block
Danger Den release their 295 full-cover water block.
If you are fortunate enough to be the owner of Nvidias flagship graphics card, the GTX295, then Danger Dens new water block is bound to be of interest.
Compatible with all the reference card designs it is a full-cover style block, to help keep the temperatures of the whole card low, rather than just the GPU chip.
It’s a sandwich of copper on the outside, with the fittings screwing directly into the copper, and a Delrin/Acetal centre to port the waterflow. This has also been designed to have low flow restriction to help maintain the pressure within your loop.
Hand lapped, pressure tested and available with all the fixtures and fittings you need.
View an pictorial installation
Visit the Danger Den product page
Discuss in our forums
