Deepcool announce their new GAMMAXX GT series CPU cooler
Deepcool has announced their new GAMMAXX GT series CPU cooler, which comes with RGB illumination and four 6mm thick heatpipes.
This new cooler will support CPUs with TDPs of up to 150W and support all modern CPU sockets like AM4, AM3(), FM2(), LGA 2011, LGA 2066, LGA 1366 and LGA 115X. This cooler will use a single 120mm RGB fan which will run at speeds of between 500 and 1500RPM and use a fluid dynamic bearing.
The GAMMAXX GT’s RGB illumination will be controlled via 4-pin RGB LED connections, making it compatible with standards like ASUS Aura and MSI Mystic light. Both the LEDs on the top of the cooler and its fan can be controlled using the method with a wide range of potential colour options.
At this time Deepcool has not announced the pricing or availability of this new cooler, though it is expected to release within the next few weeks.
You can join the discussion on Deepcool’s new GAMMAXX GT CPU cooler on the OC3D Forums.
