DeepCool launches their Mystique series of CPU Liquid Coolers
DeepCool reveals their new Mystique series of All-in-One CPU liquid coolers
DeepCool has just launched their new Mystique series of all-in-one CPU liquid coolers, offering users a 2.8-inch customisable LCD screen with a resolution of 640×480. This screen can display images, animated gifs, system information, and more.
The Mystique series of CPU coolers features the company’s 5th generation pump design. This new pump uses a 3-phase, 6-slot, 4-pole motor. This motor can spin at up to 3400 RPM while maintaining noise levels of 21 dB(A). The AIO also features a redesigned coldplate design, which is specifically designed to target the hotspots of modern CPU designs.
For the Mystique series, DeepCool are using their FT12 SE PWM fans. DeepCool’s FT12 SE fans are non-RGB and run at speeds of 500-2150 RPM and operate at noise levels of under 36.5 dB(A). These fans offer users the ability to balance between performance and acoustics.
DeepCool’s Mystique series of liquid coolers will be available in 240 mm and 360 mm radiator options. These AIOs will be available in the US with MSRP pricing of $149.99 and $179.99, respectively. We currently do know have European or UK pricing for these new liquid coolers.
You can join the discussion on DeepCool’s new Mystique series of CPU Liquid Cooler on the OC3D Forums.
