EK announced their new CryoFuel coolants
CryoFuel coolant also integrates corrosion inhibitors and will not require the use of an anti-bacterial kill-coil, with the coolant being tested in accordance with the BS5117 standard with copper, brass, aluminium, and stainless steel. These properties will maximise cooling efficiency and extend the coolants operating life.
Even with these properties this coolant is biodegradable, with coolant mixtures being 90% biodegradable within 10 days, which means that disposing of this coolant will not present any major environmental concerns.
When bottled this coolant will have a 2-year shelf life, with the coolant being available in both pre-mix and concentrated varieties in clear, blood red, navy blue, lime yellow and acid green.
This coolant is now available from EK’s web store at the above prices, with the coolant coming to partnered retailers soon.
You can join the discussion on EK’s new CryoFuel coolants on the OC3D Forums.
