EK showcases their new Fluid Gaming series of custom water cooling kits
At Computex, EK water blocks have revealed their new Fluid Gaming series of water cooling kits, which are designed to offer users everything they need for a budget friendly liquid cooling loop.
These new kits will come in both 120mm radiator and 240mm radiator options, with a pricing of $150 and $160 respectively. There will also be an additional 240mm option that will also include EK’s new Nvidia GTX 10XX Founders Edition water block design, which supports Founders Edition GTX 1060, 1070, 1080, 1080 Ti, Titan X and Titan Xp graphics cards.
Below are the three kits that are available, all of which come with EK Vardar fans, tubing, compression fittings and fluid.
A120 – Price $150, 120mm radiator and CPU block
A240 – Price $150, 240mm radiator and CPU block
A240G – Price $240, A240 kit plus an EK-AC Geforce GTX Pascal Water Block
These kits will include EK’s ACR SPC60 reservoir pump combo unit.
The pricing of this new kit does not come without compromises, with several reports claiming that these kits will use aluminium water blocks and radiators instead of copper, which could cause some material incompatibility of additional parts/metals are introduced into a water cooling loop.
Aluminium is also less conductive than copper, so this kit will not provide the same performance as its higher end copper based counterpart.
You can join the discussion on EK’s Fluid Gaming series of custom water cooling kits on the OC3D Forums.
