EK Water Blocks launches their EK-AIO 280 D-RGB CPU Cooler
Previously, EK offered this style of Closed-Loop Liquid Cooler (CLC) with 240mm and 360mm radiator sizes and 120mm fans, leaving a gap in their lineup for a 280mm option. The EK-AIO 280 D-RGB is a great all-rounder design which offers almost as much radiator area as EK’s 360mm option while also boasting support for a larger number of PC cases.
As part of the EK-AIO D-RGB series, EK fans will already know that the series offers users a great pump design that remains very quiet under load. The unit also is designed to support all major motherboard sockets, including AM4, LGA 1200, LGA 2066 and LGA 1150. The RGB illuminated fans, and CPU block can also be controlled using 3-pin 5V RGB headers, such as those on most modern RGB compatible motherboards. EK’s hardware also supports motherboard-specific RGB software suites like ASUS’ Aura Sync, Gigabyte’s RGB Fusion, MSI’s Mystic Light and ASRock’s Polychrome Sync RGB.
EK has listed their EK-AIO 280 D-RGB with an MSRP of €134.90 and backs up their units with a 5-year limited warranty. More information is available on the EK Webshop.
You can join the discussion on EK Water Block’s EK-AIO 280 D-RGB CPU cooler on the OC3D Forums.
