EK Announce availability of their R9 Fury X Water BLock
EK Announce availability of their R9 Fury X Water BLock - Press Release
EK Water Blocks, Ljubljana based premium computer liquid cooling gear manufacturer, is excited to launch the true single-slot liquid cooling solution for AMD Radeon reference design R9 FURY X graphics card. EK-FC R9 Fury X directly cools the GPU, HBM as well as VRM (voltage regulation module) as water flows directly over these critical areas, thus allowing the graphics card and it's VRM to remain stable under high overclocks.
EK-FC R9 Fury X water block features EK unique central inlet split-flow cooling engine design for best possible cooling performance. Such system also works flawlessly with the reversed water flow without adversely affecting the cooling performance. Moreover, such design offers great hydraulic performance, allowing this product to be used in liquid cooling systems using weaker water pumps. Unlike the original AIO cooling solution that comes with AMD Radeon R9 FURY X and takes up two slots, EK-FC R9 Fury X water block will transform the FURY X into a single-slot graphics card.
EK Announce availability of their R9 Fury X Water BLock  EK Announce availability of their R9 Fury X Water BLock
The base is made of electrolytic copper (bare- or nickel-plated, depending on the variant) while the top is made of either acrylic- or POM Acetal material. Plexi variants also feature two pre-drilled slots for 3mm LED diodes. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure.
Additionally the EK-FC R9 Fury X has been engineered with FC Terminal connection ports for up to four FURY X on a single ATX form factor motherboard, thus allowing for trouble-free swap out and upgrade without any additional changes to the cooling loop.
These water blocks are made in Slovenia, Europe and are readily available for purchase through EK Webshop and Partner Reseller Network. An aesthetic retention backplate, which also cools the backside of the circuit board, is also available for separate purchase and comes in five different finish variants.
You can join the discussion on EK's R9 Fury X Water Block on the OC3D Forums.
«Prev 1 Next»
07-07-2015, 19:43:34
NeverBackDown
Damn that black one looks so freaken sexy!Quote
07-07-2015, 20:25:14
Bartacus
Yummy! Quote
08-07-2015, 01:33:05
TPC
isn't it always the same? you see so many ek blocks and none are that much different, I slowly have enough of them.Quote
08-07-2015, 04:08:54
JR23
They are all extremely similar and that's a good thing. Their entire product line, which is extremely expansive, all look coherent together. Coming out with a wild GPU block design that then didn't match the CPU blocks, board blocks, pump tops... etc would be nasty. Teamed with the fact their aesthetic is so simple and they are so well finished then it makes sense for them to keep playing it conservatively.
JRQuote
08-07-2015, 04:14:44
Thelosouvlakia
Single slot cards, no bridges, QUADFIRE under water? Yes please *_*Quote
