EK Announce Water Block for ASUS GTX 980 STRIX
PRESS RELEASE
EK Water Blocks, Ljubljana based premium computer liquid cooling gear manufacturer, is proud to introduce a new Full-Cover water block, designed and engineered specificaly for ASUS Strix series NVIDIA GeForce GTX 980 graphics cards - the EK-FC980 GTX Strix.
EK-FC980 GTX Strix is a high-performance Full-Cover water block, co-developed with ASUS Republic of Gamers (ROG) engineering team. The cooler actively cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks.
 EK Announce Water Block for ASUS GTX 980 STRIX  EK Announce Water Block for ASUS GTX 980 STRIX
EK-FC980 GTX Strix water block features EK unique central inlet split-flow cooling engine design for best possible cooling performance, which also works flawlessly with reversed water flow without adversely affecting the cooling performance. Moreover, such design offers great hydraulic perfromance allowing this product to be used in liquid cooling systems using weaker water pumps.
Base is made of nickel-plated electrolytic copper while the top is made of quality POM Acetal or acrylic (depending on the variant). Screw-in brass standoffs are pre-installed and allow for safe installation procedure.
In order to simplify the search for suitable and compatible water block EK is adding newly released graphics cards and motherboard from various manufacturers to EK Cooling Configurator database and compatible graphics cards are being added to the list on daily basis:
Join the discussion on the ASUS Strix GTX 980 EK water block on the OC3D Forums.
«Prev 1 Next»
