EK Announces CoolStream CE Series Radiators
EK Announces CoolStream CE Series Radiators - Press Release
EK Announce availability of their R9 Fury X Water BLock
EK Water Blocks, Ljubljana based premium water cooling gear manufacturer, is excited to introduce the new high-performance computer liquid cooling radiators EK-CoolStream CE. EK-CoolStream CE family radiators combine EK's unique CSQ design with latest radiator core engine. Built for nearly released EK-Vardar 140mm high static pressure fans, these radiators are optimized for maximum heat dissipation across an entire fan operational range, thus delivering exceptional performance at both low- and high airflow operation.
EK Announces CoolStream CE Series Radiators  EK Announces CoolStream CE Series Radiators
EK assured quality level, optimal price-performance ratio and unique minimalistic design make these EK-CoolStream CE series radiators a perfect choice for any computer liquid cooled system. The radiator offers best cooling capacity in the 45mm thick 140mm radiator class. Dual stack copper fins provide massive surface area while the parallel flow cooling chambers reduce hydraulic flow resistance to minimum. All radiators allow for push-pull fan installation to even further increase the cooling performance.
"Our superior core design is a result of complex Computational Fluid Dynamics analysis", said Niko Tivadar, EK's Chief of R&D. "Such approach allows us to design a radiator which utilizes our flagship Vardar series fan to the maximum".
This product features two recessed G1/4 threaded ports with two pre-installed extenders from the front side to allow any G1/4 threaded fitting to be used.
The upcoming EK-Vardar 140mm series fans will be available in the first half of August 2015.
You can join the discussion on EK's CoolStream CE Series Radiators on the OC3D Forums.
«Prev 1 Next»
24-07-2015, 02:24:17
NeverBackDown
Like the plain simple look. Put that inside a FD case for an epic plainness buildQuote
