EK Introduce Blocks for GIGABYTE X99 Motherboards
PRESS RELEASE
EK Water Blocks, Ljubljana based premium liquid cooling gear manufacturer, is proud to introduce a new, universal hybrid water cooling kit for GIGABYTE® X99 series motherboards, consisting of a MOSFET water block and a passive PCH heatsink.
EK-FB KIT GA X99 LE is a value oriented hybrid water cooling solution for GIGABYTE® X99 Series motherboards consisting of VRM water block and a passive heat sink. Universal PCH cooling solution allows this product to be compatible with virtually every GIGABYTE® X99 series motherboard. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
The water block directly cools power regulation (VRM / MOSFETs) module while the passive aluminum heat sink cools Intel X99 southbridge (PCH) chip. Please note this water block cools exactly as much heat generating components as GIGABYTE factory cooling solution. The VRM cooler is a high flow water block that can be easily used with systems using weaker water pumps.
Base of the water block is made of nickel-plated electrolytic copper while the top is made of acrylic glass material. The screw-in standoffs are already pre-installed on both water block- as well as aluminum heatsink and allow for easy and trouble-free installation by utilizing original motherboard backplates.
In order to simplify the search for suitable and compatible water block EK is adding newly released graphics cards and motherboards from various manufacturers to EK Cooling Configurator database and compatible hardware are being added to the list on daily basis:
This hybrid water block kit is made in Slovenia, Europe and is readily available for purchase through EK Webshop andPartner Reseller Network:
SKU
MSRP (incl. VAT)
EK-FB KIT GA X99 LE - Nickel64,95€
Enclosed:
- water block (MOSFET)
- heatsink (SB)
- mounting mechanism
- thermal pads
 EK Introduce Blocks for GIGABYTE X99 Motherboards  EK Introduce Blocks for GIGABYTE X99 Motherboards
You can discuss EK's Water blocks for Gigabyte X99 motherboards on the OC3D Forums.
«Prev 1 Next»
08-12-2014, 08:12:40
Kushiro
Last 3 images arent working for me :I
Hopefully they decide to release some blocks for the Deluxe, though doesnt seem too likely.Quote
08-12-2014, 08:16:05
WYP
Works fine for me. Is anybody else getting this issue?Quote
08-12-2014, 08:18:50
barnsley
Its clickable but the thumbnail is broken.
http://i.imgur.com/yU71IxF.png?1Quote
08-12-2014, 08:22:16
WYP
Cheers dude, should be fixed now.Quote
08-12-2014, 08:22:38
Kushiro
Yea, getting for Barnsley is gettin. Sorry wasnt clear.Quote
