EK monoblock for ASUS MAXIMUS VIII Extreme motherboard!
EK Water Blocks, Ljubljana based premium liquid cooling gear manufacturer, is proud to close this year with a release of the ASUS MAXIMUS VIII Extreme motherboard monoblock. Very anticipated EK-FB ASUS M8E Monoblock is here!
EK monoblock for ASUS MAXIMUS VIII Extreme motherboard!  EK monoblock for ASUS MAXIMUS VIII Extreme motherboard!
ASUS MAXIMUS VIII Extreme I/O Shield is compatible with EK-FB ASUS M8E Monoblock
EK-FB ASUS M8E Monoblock is a complete all-in-one (CPU and motherboard) liquid cooling solution for Intel LGA-1151 socket Skylake CPU and the ASUS MAXIMUS VIII Extreme motherboard.
Designed and engineered in cooperation with ASUS, this monoblock uses award winning EK-Supremacy EVO cooling engine to ensure best possible CPU cooling. This water block directly cools Intel LGA-1151 socket type CPU, power regulation (MOSFET) module, as well as ASM1187e PCIe packet switch. Water flows directly over all critical areas, providing all enthusiasts a great solution for high overclocks. Like with every EK monoblock, EK-FB ASUS M8E features high flow design and this monoblock that can be easily used with the system using weaker water pump.
Base of the monoblock is made of nickel-plated electrolytic copper while the top is made of quality POM Acetal or acrylic glass material, depending on the variant.
EK-FB ASUS M8E Monoblock – Nickel (left) and EK-FB ASUS M8E Monoblock – Acetal+Nickel (right)
EK-FB ASUS M8E monoblock is made in Slovenia, Europe and is readily available for purchase through EK Webshop and Partner Reseller Network. In the table below you can find MSR prices with VAT included.
You can join the discussion on the EK VRM/CPU Monoblock for ASUS Maximus VIII Extreme motherboards on the OC3D Forums.
