EK release new Slim Series water cooling kits
EK have released new Slim Series water cooling kits, giving everything you need to set up a basic water cooling loop in one convenient package. This kit contains just about everything that a water cooling beginner requires to get started, all that needs to be added is water.
This new S series of water cooling kits are designed to be used in more compact systems or cases, where EK's existing Performance and Xtreme Series of water cooling kits will not fit. This new kit has an extra thin 25mm radiator, which will be available in radiator sizes of 120mm, 240mm and 360mm.
S-Series water cooling kits will use EK's Supremacy MX UNI CPU water block, making this kit compatible with all modern CPU sockets, be it Intel 1151, X99, AM3+ or FM2+.
 The S kits are compact starter liquid cooling kits dedicated to all users who seek the best performing, market proven components for highest chassis compatibility.
Designed for smaller cases with slim radiator in mind, the S kits are a great choice for every liquid cooling beginner and people doing small and mini ITX builds.
Customers looking for a complete CPU custom loop solution, get an affordable package with step by step instructions and don’t have to worry about compatibility issues or getting the wrong amount of fittings, too short tube or any other problems beginners face with! Each S kit will make your PC silent, highly overclockable and absolutely beautiful!
Inside this kit is a set of EK Vardar static pressure optimised fans, which are designed specifically to be used with EK water cooling radiators, allowing for optimal cooling and airflow. The kit will also include a value oriented EK-XRES 100 SPC MX PWM reservoir pump combo unit, which is designed to deliver great performance for the price.
To connect all of these water cooling components together buyers will be given 2 meters of Primochill Primoflex clear tubing, which will be used with EK's Chrome EK ACF compression fittings, which will give your PC a premium finish.
Finally, there is EK-Ekoolant Evo, which is a new concentrated coolant from EK that needs to be mixed with 900ml of distilled water before use in your system. If users want to use coloured coolants dyes and colored coolants are available on the EK storefront.
Below is a table containing the pricing and the included components in EK's S-Series water cooling kits.
ComponentEK-KIT S120EK-KIT S240EK-KIT S360
CPU Water Block EK-Supremacy MX UNI EK-Supremacy MX UNI EK-Supremacy MX UNI
Radiator EK-CoolStream SE 120 EK-CoolStream SE 240 EK-CoolStream SE 360
Water pump / reservoir unitEK-XRES 100 SPC MX PWM (incl.pump)EK-XRES 100 SPC MX PWM (incl.pump)EK-XRES 100 SPC MX PWM (incl.pump)
Radiator fan 1 x EK-Vardar F3-120 (1850rpm) 2 x EK-Vardar F3-120 (1850rpm) 3 x EK-Vardar F3-120 (1850rpm)
TubingPrimoChill PrimoFlex™ Advanced LRT™ – ClearPrimoChill PrimoFlex™ Advanced LRT™ – ClearPrimoChill PrimoFlex™ Advanced LRT™ – Clear
Compression fittings 6 x EK-ACF Fitting 10/13mm – Nickel  (3/8” – 1/2”) 6 x EK-ACF Fitting 10/13mm – Nickel (3/8” – 1/2”) 6 x EK-ACF Fitting 10/13mm – Nickel (3/8” – 1/2”)
Coolant concentrate EK-Ekoolant EVO CLEAR (conc.100mL) EK-Ekoolant EVO CLEAR (conc.100mL) EK-Ekoolant EVO CLEAR (conc.100mL)
Additional pump holderEK-UNI Pump Bracket (120mm FAN) VerticalEK-UNI Pump Bracket (120mm FAN) VerticalEK-UNI Pump Bracket (120mm FAN) Vertical
Y-Cable Splitter/EK-Cable Y-Splitter 2-Fan PWM (10cm)EK-Cable Y-Splitter 3-Fan PWM (10cm)
ATX Bridging Plug Included IncludedIncluded
MSRP (incl.VAT)189,99€199,99€229,99€
 You can join the discussion on EK's Slim series of water cooling kits on the OC3D Forums.
«Prev 1 Next»
12-05-2016, 10:27:38
Wraith
Oooh hello! I think I may have to dip my toe into the custom loop arena...Quote
12-05-2016, 11:46:48
SuB
Originally Posted by wraith View Post
oooh hello! I think i may have to dip my toe into the custom loop arena...
doooeeeeetQuote
12-05-2016, 13:08:32
Dawelio
Same here Quote
12-05-2016, 13:48:16
NeverBackDown
Same! Extremely low prices on these. Probably the 360 kit.. temptationsQuote
12-05-2016, 14:24:15
Wraith
You are so right! The temptation to go loopy is starting to make my wallet nervous.Quote
