EK release their value oriented XTOP SPC pump
EK release their value-oriented XTOP SPC pump
This article was possible thanks to information provided by RickPlaysWarr on the OC3D Forums.
EK has released their value-oriented XTOP SPC-60 water cooling pump, which is powered by a 4-pin fan header and rubber anti-vibration mounts.
This pump was recently released EK's Slim Series of water cooling kits as a pump reservoir combo, but now this unit is available as a standalone unit offering some decent performance for its low price and compact form factor.
  EK release their value oriented XTOP SPC pump  EK release their value oriented XTOP SPC pump
This unit is ideal for size constrained Mini-ITX PCs, offering a compact 62 x 62 x 51 mm (WxDxH) size while still offering a maximum flow rate of 450L/h.
The speed of this pump can be controlled via a 4-pin fan header, allowing users to control their pump speeds depending on their CPU temperatures.
The EK-XTOP SPC-60 PWM pump will be available from June 13th on the EK web store and partnered retailers for the price of €65.95.
You can join the discussion on EK's value oriented XTOP SPC-60 pump on the OC3D Forums
«Prev 1 Next»
09-06-2016, 09:55:17
Kushiro
But will it have an annoying hummQuote
09-06-2016, 10:49:40
shambles1980
looks ok for a small simple loop.. 1 rad 2 blocks.. (not highly restrictive)
but i doubt it will have decent head. and it really does not come close to a d5 and id probably recommend people spend the extra $20.Quote
09-06-2016, 15:21:13
Bartacus
Needs a better price if they're going to call it a "value" pump.Quote
