EK reveals its Socket AM5 QuantumVelocity² CPU Water Blocks
EK is ready for Zen 4
EK launches their AM5 QuantumVelocity² CPU Water Blocks, which will ship in late October
EK has just revealed a new series of CPU water blocks for AMD's upcoming AM5 CPU socket. Meet EK's AM5 QuantumVelocity², a socket-specific water block designed that is designed explicitly for AMD's Ryzen 7000 series processors.
While AMD's AM5 socket uses the same mounting hole spacing as their AM4 socket, EK has been forced to create an new water block design for socket AM5. With AM5, AMD has integrated a CPU socket backplate into their motherboard designs, a backplate that used UNC 6-32 threads that are incompatible with EK's AM4 water blocks. This necessitated the design of a new water block mounting system that supported AM5.
Like EK's other Velocity² designs, their AM5 specific water block is optimised for AMD's latest processors to deliver high levels of cooling performance and minimal flow restriction. The cold plate of this water block is designed for AMD's Ryzen 7000 series IHS and thanks to EK's use of a asymmetric plate cut-out, coolant flow is primarily directed to where it is needed most (AMD's Zen 4 CPU cores).
EK has confirmed that their AM5 QuantumVelocity² water blocks will be available in mid-October, shortly after AMD's Ryzen 7000 series launch.
Press Release - EK Announces Socket AM5 QuantumVelocity² CPU Water Blocks
EK, the leading computer cooling solutions provider, is announcing the latest generation of EK-Quantum Velocity² water blocks. These socket-specific water blocks are engineered specifically for the upcoming AMD AM5 socket and Ryzen 7000-series CPUs. Like its AM4 predecessor, the AM5 water block features EK-Matrix7 compatibility, which means it's designed according to the standard where the product's height and port distance are managed in 7 mm increments.
The product deploys a modified Velocity² cooling engine optimized for Ryzen 7000-series CPUs to ensure the best cooling performance and optimal coolant flow. While the mounting hole pattern of the new AM5 socket is still 54 x 90 mm, the AM5 motherboards now have an integrated CPU socket backplate with #UNC 6-32 threads, therefore requiring a new mounting system.
This new AM5 water block is built upon an award-winning, market-recognized Velocity² platform that received an iF Design award, a European Hardware Award, and a CES innovation award. Velocity² water blocks are on the route to outshining their predecessor and taking over the market lead.
Embedded in the Velocity² is a socket-specific, high-performance cooling engine with low hydraulic flow restriction. This is achieved through a combination of mounting pressure and cold plate geometry tailored specifically for the IHS and the die layout of the AMD AM5 socket. The lathe-turned cold plate is made with precision to cover the IHS effectively and put optimal pressure on the die area. With the help of an asymmetric jet plate cutout, the flow is also directed into areas that need it the most.
Due to the sturdy, integrated stock backplate that arrives with AM5 motherboards, the patent-pending EK-ExactMount mounting system was re-engineered for an even simpler installation process. The end result is an "invisible" and even-easier-to-use mounting mechanism, which means the entire mounting system is inside the water block, accounting for a true single-piece product. The backplate is factory-mounted on the motherboard, while the spring-loaded Torx screws are integrated into the water block and are screwed in by counter-clockwise rotation into the stock backplate of the motherboard.
The integrated mounting screws are engineered with a hard-stop design. This means that once the screws reach the end of the thread, the block is perfectly mounted and tensioned. This removes the risks of over-torquing the water block and potentially damaging your motherboard and/or CPU.
The AM5 version made for Ryzen Desktop CPUs comes in 5 variants:
- EK-QuantumVelocity² D-RGB - AM5 Nickel + Plexi - featuring a CNC-machined cast Acrylic top
- EK-QuantumVelocity² D-RGB - AM5 Nickel + Acetal - featuring a CNC-machined durable black POM acetal
- EK-QuantumVelocity² D-RGB - AM5 Nickel + Satin Titanium - CNC-machined brass top with a satin silver finish
- EK-QuantumVelocity² D-RGB - AM5 Full Nickel - featuring a CNC-machined nickel-plated brass top
- EK-QuantumVelocity² D-RGB - AM5 Nickel + Gold - same as Full Nickel and re-plated with genuine gold (not a sham
These variations are purely aesthetics-based, meaning the performance does not vary between the product variants. The cold plate is manufactured out of the highest-grade 99.99% pure electrolytic copper. The copper is machined with precision for the best contact and heat transfer possible and is then subsequently nickel-plated.
EK-Matrix7
The EK-Quantum Velocity² is an EK-Matrix7 certified product. The EK-Matrix7 is a convenient product raster that adds a new dimension to PC liquid cooling, wherein the product's height and port distance are managed in increments of 7 mm. This improves product alignment and reduces the time spent planning the loop and bending tubes. Through meticulous planning and careful design of our products, building a liquid-cooled PC becomes easy and fun, just like playing with toy bricks.
Compatibility
New EK-Quantum Velocity² series CPU water blocks are socket-specific, compatible only with the AMD AM5 socket and Ryzen 7000-Series Desktop CPUs.
The water blocks are compatible with AMD AM4 motherboards as well when using the stock backplate, but due to the variations in backplate types, the hard-stop mechanism might not work properly. Due to the changes in cold plate curvature, it's recommended to use AM4 Velocity² for AM4 socket and the AM5 version for AM5 socket motherboards.
D-RGB Compatibility
EK-Quantum Velocity² D-RGB - AM5 CPU water blocks are equipped with 17 D-RGB LEDs. Models with a clear Acrylic top are entirely lit, while the solid-top options have sophisticated light beams cutting across them. They are compatible with all popular addressable RGB sync technologies from all major motherboard manufacturers. The arrow marking on the 3-pin D-RGB LED connector is aligned with the +5V marking on the addressable RGB header.
Availability and Pricing
The EK-Quantum Velocity² AM5 series water blocks are made in Slovenia, Europe, and are available for pre-order through the EK Webshop and the Partner Reseller Network. They are expected to start shipping in late mid-October 2022. The table below shows the manufacturer's suggested retail price (MSRP) with VAT included.
MSRP
- EK-Quantum Velocity² D-RGB - AM5 Nickel + Plexi 125.90€
- EK-Quantum Velocity² D-RGB - AM5 Nickel + Acetal 125.90€
- EK-Quantum Velocity² D-RGB - AM5 Nickel + Satin Titanium 167.90€
- EK-Quantum Velocity² D-RGB - AM5 Nickel + Gold 209.90€
- EK-Quantum Velocity² D-RGB - AM5 Full Nickel 167.90€
You can join the discussion on EK's Socket AM5 Quantum Velocity CPU water blocks on the OC3D Forums.
«Prev 1 Next»
