EK's Water cooling monoblock for ASUS X99 motherboards
EK's Water cooling monoblock for ASUS X99 motherboards - PR
 EK Water Blocks, Ljubljana based premium liquid cooling gear manufacturer, is proud to release ASUS® X99 motherboard monoblock - EK-FB ASUS X99 Monoblock. It's compatible with four ASUS X99 motherboard models - X99-A, X99-DELUXE, X99-PRO, X99-S.
EK-FB ASUS X99 Monoblock is a complete all-in-one (CPU and motherboard MOSFETs) liquid cooling solution for Intel® X99 socket Haswell-E CPUs and the upcoming Broadwell-E CPUs, and the following ASUS X99 motherboards:
  • - ASUS® X99-A (USB3.1)
  • - ASUS® X99-DELUXE (USB3.1)
  • - ASUS® X99-PRO (USB3.1)
  • - X99-S
EK's Water cooling monoblock for ASUS X99 motherboards  EK's Water cooling monoblock for ASUS X99 motherboards
Designed and engineered in cooperation with ASUS, this monoblock uses award winning EK-Supremacy EVO cooling engine to ensure best possible CPU cooling. This water block directly cools Intel LGA-2011-v3 socket type CPU and power regulation (MOSFET) module as water flows directly over all critical areas. It is a very high flow water block that can be easily used with the system using weaker water pumps.
Base of the monoblock is made of nickel-plated electrolytic copper while the top is made of quality POM Acetal or acrylic glass material, depending on the variant.
      "Although we launched Intel X99 Series VRM (mosfet) blocks several months ago, we had to answer the high demand for the monoblock solution," said Niko Tivadar, EK's Chief of R&D. "Monoblocks are becoming a very popular choice with enthusiast users and we will bring two more monoblocks to the market by the end of this year."
EK-FB ASUS X99 monoblocks are made in Slovenia, Europe and are readily available for purchase through EK Webshop and Partner Reseller Network. In the table below you can find MSR prices with VAT included.
You can join the discussion on the EKWB Water Cooling monoblock for ASUS X99 motherboards on the OC3D Forums
«Prev 1 Next»
04-12-2015, 10:06:08
dwatterworth
No X99-M WS support : (Quote
04-12-2015, 15:31:37
Kushiro
Teardown time.Quote
