EKWB Releases New P Series Liquid Cooling Kits
EK has just launched their new P series of water cooling kits, giving PC builders everything they need to set up a CPU only water cooling loop in a single package.
This water cooling kit is designed to cool all modern CPU sockets an are made to be expandable into a CPU+GPU water cooling loop with ease, thanks to EK bundling their strong Revo D5 Pump/reservoir and coming in a wide range of Radiator size options.
These kits will come with EK's own Vardar Series fans, offering great performance and a high static pressure with little noise, EK's Supremacy EVO CPU Water block, EK's XRES 140 Revo D5 Pump/Reservoir and EK's own compression fittings for easy installation.
These water cooling kits will be available with 360mm, 280mm and 240mm radiators, making these kits suitable for a wide of PC cases.
All the parts used in these kits are using standardized water cooling fittings, allowing the parts to be easily upgraded or replaced in the future if the user need to.
You can join the discussion on EK's new P Series of Water Cooling Kits on the OC3D Forums
«Prev 1 Next»
03-03-2016, 09:36:37
RickPlaysWarr
Nice! I am going to be starting a conversion on my H440 / Maximus VII pc to a full loop with some case mods. These kits are almost exactly what I was going to order from EK all in one package. Add an extra radiator and some fittings and the 360 kit is perfect for what I am trying to do. Seems a great way to get into a custom loop.
--Rick--Quote
03-03-2016, 15:33:53
NeverBackDown
Even comes with there highly rated Vardar fans.. tempting kit for me as a first timer for water cooling. Depends on price as the only other full kit option is the XSPC bundlesQuote
