Enermax launches their sleek ENERMAXK8 chassis in Europe
The ENERMAXK8 PC case is now available in Europe
Enermax’s new ENERMAXK8 PC case has now arrived in Europe. This new ATX PX case option gives users side panels that are a mix of solid steel and tempered glass.
At launch, this new PC case will be available in black and white, and ship with three pre-installed ARGB fans. These fans can be controlled with your motherboard’s RGB software, or Enermax’s included controller. This RGB controller has 21 built-in lighting modes.
This case’s front panel features a removable tray with space for up to three fans. I supports liquid coolers up to 360mm in size, and can be mounted with thumb screws for easy installation. At the front of the case, users have I/O options in the form of a UBS 3.2 Gen 1 Type-A port and a USB 3.2 Gen 2 Type-C port. Moreover, behind this case’s motherboard tray there is a 6-way fan/RGB controller.
Enermax’s new ENERMAXK8 chassis is available for €119.90 in Europe at Alternate. However, Enermax are selling this case with one of their LIQMAXFLO 40 ARGB liquid cooling solutions for €159.80. This bundle is €60 cheaper than both products separately.
You can join the discussion on Enermax’s ENERMAXK8 PC case on the OC3D Forums.
