Golden Field releases GeForce RTX-inspired PC cases in China
Is this the perfect PC case for an RTX-powered PC?
A Chinese manufacturer called Golden Field has created a new lineup of PC cases that’s perfect for users of Nvidia’s GeForce RTX graphics cards. Clearly, these new PC cases are inspired by the aesthetic of Nvidia’s latest GeForce RTX Founders Edition graphics cards. This makes these cases perfect for RTX-powered gaming PCs or workstations.
Golden Field’s RTX-inspired cases come in two sizes. There is a larger LITE model that measures in at 471 x 220 x 459mm, and a smaller NANO model that measures 378 x 220 x 459 mm. Note that the only dimension that changes is the case’s depth. This change allows the larger LITE model to support longer graphics cards.
(Golden Field Lite – Image from Videocardz)
Cooling-wise, the Golden Fields LITE supports up to a 360mm liquid cooling radiator at the top of the case, while the smaller NANO model only supports up to a 240mm liquid cooling solution. Both cases support ATX motherboards, large CPU coolers (up to 174mm tall), and multiple 3.5-inch HDDs.
(Golden Field Nano – Image from Videocardz)
Honestly, if Nvidia manufactured pre-built gaming PCs, they’d probably look something like this. Golden Field has perfectly mimicked Nvidia’s Founders Edition aesthetic. Sadly, this PC case is only available in China and is unlikely to become available in Western markets.
You can join the discussion on Golden Field’s GeForce RTX-inspired PC cases on the OC3D Forums.
