ID-Cooling Releases a new vapour chambered M-ITX Cooler
PRESS RELEASE
ID-COOLING, a cooling solution provider focusing on thermal dissipation and fan technology research and production for over 10 years, releases a newly developed Vapor Chamber CPU Cooler for Mini-ITX system: IS-VC45.
When small PC systems get more and more power hungry and house much more top-tier hardware including the CPU, effective CPU cooling is in demand. With a vapor chamber base to draw heat immediately from the processor, IS-VC45 is able to handle TDP 130W CPUs. Measuring 94×92×45mm, this cooler can fit into Mini-ITX systems easily.
 ID-Cooling Releases a new vapour chambered M-ITX Cooler  ID-Cooling Releases a new vapour chambered M-ITX Cooler
High density aluminum fins are soldered to the vapor chamber base to help disperse the heat. Equipped with a slim 92mm FDB(Fluid Dynamic Bearing) fan, IS-VC45 can dissipate heat efficiently while keeping at a decent quite operation. The speed is regulated between 600 to 2500RPM with PWM function.
Using metal screws and back plate installation, this cooler will stay safely on your motherboard. Intel Socket LGA1150/1155/1156 and Socket LGA2011 are supported.
MSRP for IS-VC45 is $44.99.
Join the discussion on ID-Cooling's New M-ITX cooler on the OC3D Forums.
«Prev 1 Next»
19-01-2015, 06:31:38
AverageNinja
Looks pretty nice I think. Looks a bit like the Prolimatech Samuel 17 cooler imo!Quote
19-01-2015, 06:40:37
Feronix
Why would they use brown fans other than imitating Noctua though? :|Quote
19-01-2015, 20:27:48
SgtT8ie
I'm interested... would suit my new Asus Z97-I. Tough to match the chocolate brown to other components though.Quote
19-01-2015, 20:31:10
Dicehunter
Well if I ever want to make a dog crap colour themed rig I know which cooler I'm getting Quote
19-01-2015, 20:38:53
NeverBackDown
I don't know why but those fan blades look identical to the Fractal Design fans.. which isn't good for static pressure i might addQuote
