In-Win's Z-Tower Signature Edition Chassis will cost €5,499
Wow, this case is stupidly expensive...
Published: 20th December 2018 | Source: Caseking |
At its launch, In-Win didn't reveal the pricing of their 8th Generation Signature case design, which meant that it wasn't going to be cheap. Anyone involved in metalworking knows that sand casting molten aluminium on this scale isn't a cheap process, with the Z-Tower requiring a large amount of work from both man and machine. Producing a Z-Tower is a lot more labour intensive than standard PC cases.
Now, thanks to Caseking, we know the price of In-Win's Z-Tower. At the time of writing the case costs €5,499, which to put into perspective is worth more than two Titan RTX graphics cards, which already costs more than most high-end gaming systems.
In-Win's Z-Tower will ship in early January 2019 in limited quantities. Each case will be numbered, allowing owners to know how many cases came before their model.
You can join the discussion on In-Win's Z-Tower Signature Edition Chassis on the OC3D Forums.
I still like it though, and it's still chump change to a millionaire.Quote
The only sad thing about this is that due to the price it will never end up in the hands of modders.
I still like it though, and it's still chump change to a millionaire. |
Trying to work out the cost right now for 40Kg of cast aluminium.
EDIT: Going rate as of right now is £1.90 per kilo (21/12/2018) so that's £76 for the alloy then machining costs, it's a hell of a margin InWin are adding.Quote
It'll only be modders that get these oh and maybe Terry Cruz
![]() Trying to work out the cost right now for 40Kg of cast aluminium. EDIT: Going rate as of right now is £1.90 per kilo (21/12/2018) so that's £76 for the alloy then machining costs, it's a hell of a margin InWin are adding. |
