In Win announce their limited edition H-Frame 2.0 30th anniversary case
In Win announce their limited edition H-Frame 2.0 chassis, which has been created the celebrate the companies 30th anniversary. This case will come with an In Win 1065W PSU which offers 80+ Platinum efficiency and a 5-year warranty.
This chassis will cost £1199.99 and weighs in at 25.52kg. This case supports motherboards up to EATX in size and comes with tempered glass windows and built in USB 3.0 and 1x USB 3.1 type-c connections.
In Win announce their limited edition H-Frame 2.0 30th anniversary case  In Win announce their limited edition H-Frame 2.0 30th anniversary case
This case comes built in Amber LED lighting and supports water cooling with a top-mounted 360mm radiator.
CASE SPECIFICATION
Model: H-Frame 2.0
- Colour: Black/Amber LED Light
- Case Type: Full Tower
- Case Material: Aluminium, Tempered Glass
- M/B Compatibility: 12" x 13" E-ATX, ATX, Micro-ATX
- Expansion Slots: PCI-E x 8
- High-end Graphics Card Compatible Length: 330mm Maximum (With HDD Tray), 440mm Maximum (Without HDD Tray)
- Front Ports: 3 x USB 3.0, 1 x USB 3.1 Type-C, HD Audio
- Internal Drive Bays: 6 x 2.5"/3.5" - Supports SATA HDD EZ-Swap Module x 2
- Thermal Solution Compatibility: 1 x 120mm Rear Fan, 3 x 120mm Top Fan, 1 x 360mm Top Radiator, CPU Cooler - 185mm from CPU die to side panel
- Power Supply Compatibility: SII-1065W Internal PSU Included, PSII: ATX12V and EPS12V - Length: 210mm Maximum
- Product Dimension (H x W x D): 597mm x 271mm x 582mm 23.5" x 10.6" x 22.9"
- Package Dimension (H x W x D): 365mm x 712mm x 834mm 14.4" x 28" x 32.8"
- Net Weight: 19.12kg/42lb
- Gross Weight: 25.52kg/56lb
POWER SUPPLY SPECIFICATION
- Model: SII-1065W
- Total Power: 1065W
- Type: ATX12V V2.4/ EPS12 V2.92
- Cable Management: Fully Modular
- PFC: Active PFC ( >0.9)
- Efficiency: 80 Plus Platinum
- MTBF (Hours): >100,000
- AC Input: 100 - 240Vac. 6.5-13A 50-60Hz
- Hold-up time (ms): >16ms
- Fan: 165mm Slient Fan
- Fan Size: 165mm*25mm
- Typical Fan Noise (dB): < 25dB
- Full Protection: OCP / OVP / UVP / SCP / OTP / OPP
- Safety Certifications: cTUVus / TUV / CB / BSMI / CE / FCC / EAC / CCC / RCM / KC
- Dimension (L x W x D): 210 x 180 x 86mm
- Weight: 2.8kg
CONNECTORS
- 1 x 20+4-Pin ATX12V/EPS12V
- 1 x 8-Pin EPS12V
- 2 x 4+4-Pin ATX12V/EPS12V
- 8 x 6+2-Pin-PCIe
- 10 x SATA
- 9 x 4-Pin-Molex
- 3 x Floppy
- Warranty: 5yr
You can join the discussion on the In Win H-Frame 2.0 chassis on the OC3D Forums.
«Prev 1 Next»
20-07-2016, 07:18:06
Thelosouvlakia
That power supply though <3Quote
20-07-2016, 10:40:37
Wraith
This chassis is epic I watched Davido_Libido do a live unboxing and it was just pure nerd pron.Quote
20-07-2016, 11:24:34
Dawelio
Is it just me that thinks these In Win cases are insanely priced and just absolutely ridicolous?... I wouldn't even pay £50 for this case lol.
I agree with Thelosouvlakia though, that PSU does look quite nice.Quote
20-07-2016, 11:41:41
SuB
..YepQuote
