In Win H-Tower Full Tower Aluminium Motorized Chassis
In Win H-Tower Full Tower Aluminium Motorized Chassis now available for purchase at Overclockers UK for the price of  £1899.95.
This new case offer unique mechanical functionality, allowing the case to transform and change colour wireless and with In Win’s unique mobile app. When the H-Tower is in motion, the side panels unfold outwards to reveal a spacious interior with the motherboard main plate rotating 90 degrees to showcase your hardware.
While this case my be more expensive than the majority of full systems out there it is no doubt one of the most unique cases out there in terms of functionality. One could say that this case is a lot more than meets the eye.
       Inside E-ATX (12 x 13-inch), ATX and micro ATX motherboards are supported with excellent water or air cooling options – three 120mm fans (or 360x35mm radiator) and 195mm tall CPU heatsinks – and up to eight, 340mm long internal expansion slots for GPGPU workstation builds or 4-way multi-GPU gaming rigs.
Two 3.5-inch and 2.5-inch bays are available for internal storage, and up to four USB 3.1 ports, including one Type-C port, are included up front. Large ATX12V PSII and EPS power supplies up to 220mm can be installed.
An official ASUS Republic of Gamers certified version is available in red and black, with ROG logo with Maya patterned features. Other color options include burnt orange and black and classic Titanium-black. Availability of each is subject to market.
IN WIN H-Tower
SPECIFICATION
– Material: Aluminium, SECC
– Colour: Black/Red
– Internal Drive Bay: 3.5” x 1, 2.5” x 4
– M/B Form Factor: E-ATX (12” x 13”), ATX, Micro-ATX
– Power Supply: ATX12V, PSII and EPS
– Power Supply Mounting Area: Length up to 230mm
– I/O Port: USB3.1 Type C (19-pin) Connector x 1, USB3.0 Type A Connector x 3, HD Audio
– I/O Expansion Slot: PCI-E Slot x 8
– Supports High-end Graphic Card (Length up to 340mm, Height up to 200mm)
– Thermal Solution: Supports 120mm Top Fan x 3, 360mm Radiator (Height up to 35mm), Supports at Least 200mm Height CPU Heatsink Based on Different Mounting Position
– Dimension (HxWxD): Closed: 617 x 322 x 502mm (24.3″ x 12.7″ x 19.8″), Open: 620 x 680 x 785mm (24.4″ x 26.8″ x 30.9″)
– Net Weight: 23.03kg
– Gross Weight: 32.1kg
You can join the discussion on In Win’s H-Tower chassis on the OC3D Forums.
