In Win's 509 Chassis is now available for Pre-Order
In Win's 509 Chassis is now available for Pre-Order in the UK, sporting a front and side tempered glass panels and an RGB illuminated logo which supports 4-pin motherboard LED solutions.
This chassis comes in at £159.99 and will come in Red/Black and Black/Grey, with the Red/Black version being ROG certified.
   Consistent with In Win’s distinguishable feature of previous chassis, the 509’s front and side panel are both composed of tempered glass.
The In Win 509 even comes with a RGB logo that’s powered by a 4-pin connector (compatible with motherboards with RGB headers).These provides users with incredible visual experience.
This chassis comes with four 2.5" drive mounts and five 3.5"/2.5" drive mounts, three of which are modular. This makes this chassis capable of holding even the beefiest of storage setups while keeping the internal aesthetic clean and tidy.
In Win's 509 also supports 360mm radiators at the front, making this chassis perfect for custom water cooling and even contains a built-in GPU support which will help prevent your graphics card from sagging.
 In Win's 509 Chassis is now available for Pre-OrderIn Win's 509 Chassis is now available for Pre-Order
Inside this chassis also supports three internal 120mm fans, allowing you to direct airflow through the chassis for optimal cooling.
This In Win 509 is currently available to Pre-Order here for £159.99.
You can join the discussion on the In Win 509 RGB chassis on the OC3D Forums
«Prev 1 Next»
13-09-2016, 12:16:18
Dark NighT
That optical bay ruined it. connections could have been on the roof for a super clean front, other then that, it does look pretty cool.Quote
13-09-2016, 16:37:04
russler
ive wanted an in win case for so long.... but the 750d is just too good and i can roof mount the radiator, they were so close to my perfect case ;(Quote
