In Win's ultra-compact B1 Mini-ITX Chassis is ideal for your next low-power PC
This is as small as ITX gets
One of the main perks of the Mini-ITX form factor is its size, but this advantage lessens when combined with large graphics cards, cooling solutions or other standard-sized components.
With its new B1 chassis, In Win has created a Mini-ITX chassis that goes as small as the form factor can be expected to go, creating an incredibly compact and lightweight case that's ideal for use as an HTPC, office PC or as a PC for light gaming.
Overall, the enclosure measures in at 108mm x 302mm x 238mm, making this case smaller than the boxes of some PC components. The case ships with an integrated 200W power supply, which is 80+ Gold rated, ensuring that the unit will be cool and quiet under load. Sadly, this case supports no PCIe slots, which restricts this case to processors with integrated graphics. That said, with a 200W power limit, discrete graphics were already out the window for this enclosure.
The main perks of In Win's B1 are its size and its appearance. If you need a small, lightweight PC for your office, this enclosure is ideal, especially if you want something that's stylish and outside of the norm.
Cooling-wise, this enclosure relies on a single 80mm fan for airflow, and supports CPU coolers that are up to 60mm tall. The enclosure also supports two 2.5-inch drives, which combined with the M.2 storage potential of modern ITX motherboards, enables a lot of storage potential to end-users.
Air intakes for this enclosure are dust filtered, and the case's power supply is designed specifically to fit within the B1's small footprint. This power supply has a 3-year warranty.
Overall, this case has been designed using ABS plastic and Tempered Glass as the enclosure's primary materials. This makes the In Win B1 durable and lightweight. Overall, the case weighs about 1.9 kg.
You can join the discussion on In Win's Mini-ITX B1 Chassis on the OC3D Forums
«Prev 1 Next»
10-04-2020, 11:57:13
AlienALX
Awesome. Would make a beautiful cinema rig that.Quote
11-04-2020, 21:34:53
ET3D
Nice case. Would be a good match for a Renoir desktop APU once they're released.Quote
