InWin showcase two cases with wooden parts
InWin have started showing off two new case designs at Computex, which combine wood, glass and aluminium to create a striking aesthetic.
The first of these new cases is the InWin 806, which is an ATX mid-tower that comes with a with a treated plywood exterior, creating a very different external aesthetic than the company’s traditional brushed aluminium designs.
This chassis will come with a body that is primarily constructed out of aluminium, with the chassis also featuring a tempered glass window.
The second chase that InWin have shown is the Gaming Cube A1, which comes with a 200mm x 268mm x 340mm footprint and enough space for an ITX motherboard and a 2.5-slot GPU that is up to 31.5mm in length.
This chassis will have enough space for an internal SFX power supply and for a 120mm intake and exhaust, with very limited space for a CPU cooler. On the top of this case is a treated wooden panel, giving this case a unique aesthetic that would be very suitable for a minimalistic office.
You can join the discussion on InWin’s new prototype wooden cases on the OC3D Forums.
