Lian Li announce their PC-T70 test bench
Over the year many have complained about the use of open air test benches, especially when recording thermal results in reviews. This is why it is OC3D’s policy to test hardware inside proper PC cases, as it more closely matches the results that users can achieve at home.
The PC-T70 will release at the end of May with a price of £99.99 at Overclockers UK, which is a very reasonable price for a test bench like this, especially from Lian Li. This chassis will be available in both Black and White, offering support for GPUs up to 330mm in length and up to five 2.5-inch drives 1 3.5-inch HDD or one 2.5-inch drive and dual 3.5-inch drives.
The base PC-T70 offers support for up to a 280mm or a 360mm radiator on the bottom, with the T70-1 add-on offering support for additional fan mounts.
The PC-T70 is designed to offer the best of both worlds when it comes to PC hardware testing, being usable as a fully open-air test bench and as an enclosed chassis for more accurate/real-world hardware testing.
This chassis will release in late May for £99.99, though the price of the T70-1 add-on is unknown.
You can join the discussion on Lian Li’s PC-T70 test bench on the OC3D Forums.
