Lian Li targets value with its UX100 PC case
Lian Li unveils its $99 UX100 PC case at Computex 2026
Lian Li is doing a lot of interesting things with tempered glass at Computex 2026. First, we had their LANCOOL 4 PC case, which places fans on its front tempered glass panel. With the upcoming UX100, Lian Li has built a 3-sided panoramic glass PC case that still provides PC builders with plenty of airflow.
For $99, the UX100 is a great-looking PC case with a clever “floating” design that enables strong airflow in its primary chamber. This provides the UX100 with a chimney-style bottom-up airflow pattern, giving GPUs access to cool outside air. The case’s panoramic glass design gives users a clear view of their PC hardware, and integrated RGB LED lighting strips highlight these details.
The UX100 is an ATX-sized PC case that supports large graphics cards and liquid cooling solutions. Below, we can see a system build with a 360mm CPU liquid cooling solution installed, and a large Gigabyte Aorus RTX graphics card.
Lian Li says that their models on the Computex show floor are prototypes. That means that some design elements of this case could change before its planned launch in Q3 2026. For $99, this case should represent strong value for money at launch, assuming it can deliver solid GPU-focused airflow.
We have confirmed that Lian Li plans to release this case in Black and White. No other colour options have been confirmed. The LED lighting strips in this case are RGB. That means that users can set their PC’s highlight colour to whatever they want.
You can join the discussion on Lian Li’s UX100 PC case on the OC3D Forums.
