Lian Li Announce Budget Friendly PC-K5, K6 and K6S cases
Lian Li has announced their new range of  budget friendly cases, starting with their PC-K5, PC-K6 and PC-K6S cases. These cases are designed to offer PC builders the quality that you would expect from Lian-Li, but at much more attractive pricepoints, coming with a lot of the same tool-less features, grommeted cutouts and cable management options that you would expect from a higher end chassis.
All three of these cases are designed to offer full support for ATX sized motherboards, full sized Power supplies and have enough space to fit a 60mm thick 240mm radiator at the front of the chassis.
The PC-K5 is Lian Li's entry level chassis, which offers pretty much everything that a PC builder needs to get started for the affordable price of £42.90, though the higher end offerings offer features like greater water cooling support, a PSU covering shroud and even sound dampening material on the PC-K6S.
Below are the specifications for Lian Li's three new mid-tower cases: The PC-K5, PC-K6, and PC-K6S:
  • - All support 120mmx240mmx60mm(K5) or 140x280mmx60mm(K6, K6S) radiators at the top of the case
  • - Full ATX and mATX motherboards, seven expansion slots each
  • - All include three 120mm fans
  • - PC-K5: 250mm VGA cards (400mm without drive cages), 250mm PSUs, and 160mm CPU coolers
  • - PC-K5: up to four 3.5” or 2.5” drives
  • - PC-K6 and PC-K6S: 310mm VGA cards, 310mm PSUs, 170mm CPU coolers
  • - PC-K6 and PC-K6S: up to seven 3.5” or 2.5” drives
  • - USB 3.0, USB 2.0, and HD audio inputs on each case
  • - Noise-isolated foam panels on the PC-K6S “silent” model
On the PC-K6 and K6S users will also be able to remove the covers for the drive bays and the PSU using thumb screws, giving you easy access while building and the opportunity to easily cover up your cables.
 Lian Li Announce Budget Friendly PC-K5, K6 and K6S cases  Lian Li Announce Budget Friendly PC-K5, K6 and K6S cases
The MSRP of Lian Li's PC-K5 is £42.90, with a £49.20 windowed version and the PC-K6 will cost £79.70 and the noise dampened PC-K6S will cost £89.90.
These cases will become available to purchase in early June at Overclockers UK.
You can join the discussion on Lian Li's budget friendly PC-K5 and PC-K6 cases on the OC3D Forums
«Prev 1 Next»
18-05-2016, 08:46:56
Kushiro
A budget friendly case from Lian Li Quote
18-05-2016, 12:29:21
Wraith
Jokes! I had to read that twice, "Lian Li" and "budget" not 2 words you generally hear together.Quote
22-05-2016, 18:03:30
GiantKiwi
Probably need them to cover their bottom line Quote
22-05-2016, 20:09:17
RobM
The K5 is plain ugly I think they missed an opportunity there to save more on cost and go with no optical bay or just 1 and with only 1 usb 3
The K6 is more on the mark in terms of looks I think they would have been better overall instead of the k5's doing a 3rd K6 with windowQuote
23-05-2016, 00:03:18
Firedrops
Is nobody else noticing that they're charging 10 pounds for the dampening material?Quote
