Lian Li Announces The PC-X510 Tower Chassis
Lian-Li Industrial Co. Ltd unveils the PC-X510: a mid tower chassis with a tidy, spacious interior segregated into three distinct airflow chambers for optimal cooling and tempered glass to show it off. The PC-X510 has generous allowance for components, supporting as many as eight 2.5" or 3.5" drives and eight expansion slots.
The Case is trisected into three airflow chambers. Three 120mm fans pull air through two long intakes along the front of the side panels. Each is covered by a washable magnetic mesh air filter strip. An additional two 120mm fans vent the top and central compartments, while the PSU exhausts the bottom compartment itself. This divides the airflow between the PSU, motherboard, and drive bay area so they don't influence each other. The included fan controller helps get the cooling just right.
        Lian Li Announces The PC-X510 Tower Chassis  Lian Li Announces The PC-X510 Tower Chassis
Modular Customization Options
The top compartment of the PC-X510 features two removable drive trays mounted on shock-absorbing rubber grommets. Each tray holds two drives for a total of four 2.5" or 3.5" drives. One or both of the trays can be removed to accommodate ambitious cooling setups - up to two more additional 120mm fans or a 240mm water cooling radiator. An additional mount is located behind the motherboard allowing one tray to be hidden in the rear. It can be relocated from the top, or purchased separately to complement the two included, making a total of up to six vibration-dampened drives.
In the main compartment, two additional drives can be mounted on top of the PSU enclosure, bringing the grand total to eight! The three 120mm intake fans are mounted on a tool free holder; it can be taken out with ju st two thumb screws and replaced with a full-sized 360mm water cooling radiator. Pre-punched holes are located near the eight expansion slots to mount the optional tool free PCI retention system: http://www.lian-li.com/en/dt_portfolio/pci-01/
Full Tower Build in Mid Tower Size
The PC-X510 can fit full-sized gaming components in its slim mid tower frame. The case weighs only 7.8Kg yet packs eight expansion slots with 330mm of room for cards. It can fit CPU coolers 180mm tall and ATX power supplies 245mm long. A huge tempered glass side panel window allows builders to flaunt the large hardware this case can accommodate.
Generous Connectivity and Features
The PC-X510 offers HD audio in/out and four USB 3.0 ports on its top panel with a sliding cover. All air filters are removable, washable, and replaceable. The case stands on aluminum stands with rubber feet to prevent slippage. The back panel features liquid cooling grommets with mouse ears to allow external all-in-one water cooling kits to pass inside the case. The PC-X510 also includes a fan controller to adjust fan speed between 60% and 100%.
Price and Availability
The PC-X510 will be available for $399 in US in early September.
Product Features of the PC-X510
  • - Isolated air chambers for efficient cooling
  • - Fits huge components - 330mm VGA Card, 180mm CPU cooler, 245mm PSU length
  • - Eight expansion slots
  • - Support for eight total drives
  • - Tempered glass window for showing off hardware
  • - Included fan speed controller
  • - Availability in US: Early September
  • - MSRP: USD $399
For more information, visit the product page.
You can join the discussion on Lian Li's PC-X510 Chassis on the OC3D Forums.
«Prev 1 Next»
16-09-2015, 16:58:27
CreatiXx
looks this case has some serious potential ;o but lian li knowing it comes with a price.. ^^Quote
17-09-2015, 06:01:18
SuB
The window looks utter gash, apart from that.. this has potential, look at all that room in the top for... activities!!Quote
17-09-2015, 06:35:06
Dicehunter
A mid tower with the price tag of $399.99 ???
Ok someone smoked a maHOOsive bag of weed in the office the day they were coming up with that price XDQuote
17-09-2015, 06:39:03
SuB
You've obviously never owned a Lian-Li ? they're lushQuote
17-09-2015, 06:57:35
Dicehunter
We have a Lian Li Tyr PC-X1000 in work from around 2009/10, Honestly can't see what the fuss is about even back then when it was new.
The only Lian Li case that has ever made me go "Ooooh hello" is the PC-07, Now that looks good Quote
