Lian Li Wall-Mountable Cases
PRESS RELEASE
Lian-Li Industrial Co. Ltd, today launches the O Series open-air, wall-mountable chassis: PC-O5, PC-O5S, PC-O6S and PC-O7S. Previewed to the worldwide technology community in its prototype stage, the O Series chassis final design reflect the feedback of the DIY community, and feature oversized tempered glass windows, a PCI riser cards, and sleek aluminum construction.
The new O series includes four chassis: the mini-ITX PC-O5, the mini-ITX PC-O5S, the micro-ATX PC-O6S, and the ATX PC-O7S. These aluminum constructed cases all feature a similar design and aesthetic differing in their hardware compatibility. Through the oversized tempered glass window, onlookers can see the entire build unrestricted. Graphics cards are installed parallel to the motherboard, keeping the chassis slim, thanks to the included PCI riser card and extension. A black anodized aluminum shield covers the hard drive cage to keep a super clean look.
Lian Li Wall-Mountable Cases  Lian Li Wall-Mountable Cases
Customizable Storage Options
The O Series chassis give builders several options for storage installation. Hard drives can be mounted in the hard drive cage, hidden by an anodized aluminum shield, directly mounted on the motherboard tray, or installed on a removable bracket behind the motherboard.
Water Cooling Support
The PC-O5S, PC-O6S, and PC-O7S support AIO water cooling systems. The "S" suffix in the aforementioned models denotes water cooling compatibility. The PC-O5S supports radiators up to 240mm, while the PC-O6S and PC-O7S supports 360mm radiators.
Versatile Placement
The O Series cases can be mounted to the wall, placed on a desk in the vertical position using the included aluminum stand with rubber grip, or arranged horizontally on four attachable feet with rubber padding.
Product Features of the O Series Chassis: PC-O5, PC-O5S, PC-O6S, PC-O7S
    • Open-Air Chassis
    • Oversized tempered glass panel
    • Wall-mountable
    • Can be placed in a vertical or horizontal position on a desk
    • Some models with AIO water cooling support: PC-O5S, PC-O6S, PC-O7S
    • Aluminum construction
    • MSRP:
PC-O5 : $ 289
PC-O5S: $ 319
PC-O6S: $ 379
PC-O7S: $ 419
Available soon
Join the discussion on Lian-Li's Wall mountable O series of cases on the OC3D Forums.
«Prev 1 Next»
18-12-2014, 11:52:50
The_Governour
what? no link?Quote
18-12-2014, 11:53:19
Cru
Originally Posted by The_Governour View Post
what? no link?
give it a minuteQuote
18-12-2014, 17:34:47
CreatiXx
it looks nice but euhm.. i've always thought this about lian li but it seems a bit overpriced imo?Quote
18-12-2014, 17:40:35
Wraith
Noice! I do love a solid quality Lian Li chassis, would love to see the rawl bolts needed to hold that MATX to a wall.Quote
18-12-2014, 20:36:08
DamianThorg
Looks like an awesome case. It has been a while since I have been interested in a Liana Li case... I could see this as my new media PCQuote
