Look ma, no fans! – YPlasma is bringing noiseless plasma-cooled laptops to CES 2026
YPlasma’s giving laptops a fan-free future with its Dielectric Barrier Discharge (DBD) tech
YPlasma is coming to CES 2026 and plans to showcase a technology that could make all future laptops virtually silent. YPlasma is eliminating cooling fans and replacing them with Dielectric Barrier Discharge (DBD) plasma actuators, bringing space-grade technology to consumer devices.
By using cold plasma, Yplasma’s solid-state cooling technology can generate high-velocity “ionic wind”, pushing air without any moving parts. Operating at 17 dBA, Yplasma’s tech is almost noiseless. Regardless, it is powerful enough to cool high-performance laptops while taking up less space than a traditional fan.
While this style of cooling solution is not new, prior attempts at this technology have had issues. For starters, “corona discharge” devices tend to produce ozone, a harmful byproduct. Additionally, tip erosion can be a problem, acting as a primary failure point for these devices. YPlasma’s tech eliminates these issues with ozone-free operation and increased longevity. Yplasma’s protected electrode design is said to last the entire lifespan of laptop devices, though the company has not stated an exact lifespan expectation.
A blessing for future ultra-thin devices?
YPlasma claims that their technology is packaged in a 200-micron film, allowing this “space-grade” technology to be used everywhere. For laptops, this could enable thinner devices and new heatsink designs. Furthermore, this technology is versatile enough to be used across a broad range of industries. While silent laptop cooling is an excellent use case, it isn’t the only place where quiet air movement is desirable.
You can join the discussion on YPlasma’s noiseless laptop cooling solution on the OC3D Forums.
