MSI announce their new TORX series 120mm series fans
MSI has now revealed their new TORX series of 120mm PWM fans, offering the same fan design as seen in the companies recent Core Frozr series of CPU coolers.
What is interesting about this new fan design is that it comes with a new, patented impeller design, using two different types of fan blades which are designed to both increased airflow and static pressure. This fan design will use a standard square design and comes with four rubberized mounts, with power coming from a 4-pin fan header.
These fans will come with a 500-1,800 RPM range with airflow ratings of 19.79-71.27CFM, with noise outputs of between 17.2-33.6dBA.
Right now MSI has not revealed the pricing or release date of this new standalone fan design.
You can join the discussion on MSI's new TORX series of 120mm fans on the OC3D Forums.
«Prev 1 Next»
04-03-2017, 12:04:06
NeverBackDown
I like it.
The red on it it meh but it has no RGBs and that makes me happyQuote
04-03-2017, 12:11:09
AlienALX
They would look nice if you had a MSI gaming GPU Quote
04-03-2017, 13:28:47
Dark NighT
I have but its green/black lol
These do look pretty cool.Quote
04-03-2017, 17:01:17
PaddieMayne
I like em, how much? and where can I get em?Quote
