Noctua is ready for next-gen CPUs
Noctua confirms that its CPUs are ready for Intel’s LGA-1954 socket
Noctua has updated its official FAQ to confirm that all of its LGA-1851- and LGA-1700-compatible CPU coolers will be compatible with Intel’s next-gen LGA-1954 CPU socket. This means that all of Noctua’s current-generation Intel-compatible CPU coolers will support Intel’s next-generation Nova Lake processors.
The best part of this news is that Intel’s LGA-1851 and LGA-1700 CPU coolers will not need new mounting hardware to support Intel’s next CPU socket. The installation process is the same as LGA-1700/1851. This means most of today’s CPU coolers will support Intel’s next-generation processors.
All Noctua CPU coolers that are compatible with LGA1851 and LGA1700 are also compatible with Intel’s upcoming LGA1954 socket.
No additional mounting parts are needed. Please follow the installation steps for LGA1700/LGA1851, as the installation process is identical.
– Noctua
Intel’s next-gen Nova Lake CPUs are due to launch in 2026, and Noctua is ready for that transition. On the AMD side, Noctua has released no new guidance, implying that AMD plans to stick with its AM5 socket. This means AMD fans should not expect AM6 to be unveiled anytime soon. AMD’s upcoming Zen 6 CPUs should use AMD’s AM5 socket.
Rumour has it that Intel intends to support its LGA-1954 socket long-term. In other words, LGA-1954 should support more than two generations of processors. LGA-1954 could be a long-lived CPU socket, like AMD’s AM4 and AM5 sockets. If true, this means that Noctua’s current-generation CPU coolers will support new Intel CPUs for the foreseeable future.
You can join the discussion on Noctua’s planned LGA-1954 support on the OC3D Forums.
