Noctua will not be releasing any Threadripper TR4 mounting kits for their existing coolers
This lack of upgrade options is due to the sheer size of AMD’s new EPYC/Threadripper CPUs, as standard Noctua heatsinks will only cover around 50% of the IHS of AMD’s latest CPU platforms. This means that even with a mounting kit upgrade, almost all of Noctua’s existing coolers will simply be unable to offer sufficient cooling performance.
Can I upgrade my existing Noctua cooler to socket TR4 or SP3?Unfortunately, it is not possible to upgrade existing Noctua heatsinks to support the AMD TR4 and SP3 sockets for Ryzen Threadripper (X399) and Epyc CPUs. TR4/SP3 CPUs have much bigger heatspreaders (as compared to e.g. LGA2066 or AM4 processors) and the contact surfaces of standard Noctua heatsinks would cover only about half of these heatspreaders, which would result in insufficient cooling performance. For this reason, Noctua will soon introduce new cooler models that feature bigger contact surfaces that have been tailored to fit TR4/SP3 CPUs. Please choose these models for AMD Ryzen Threadripper and Epyc systems.
At this time it is unknown when Noctua will be releasing these new CPU coolers onto the consumer market, or how they will be priced when compared to their standard counterparts.
You can join the discussion on Noctua’s support for AMD’s Threadripper and EPYC CPU platforms on the OC3D Forums.
