NZXT launch their new Aer F series of fans and coloured Trim packs
NZXT has launched their new Aer F series of fans and a selection of coloured Trim packs for their existing Aer fan lineup. These new fans are designed for high airflow situations,
These new F-series fans are designed for high airflow situations, producing powerful airflow with minimal drag and vibration, making them ideal for places where high levels of static pressure are not required.
These new Aer F series fans will come with the same chamfered intake and exhausts as NZXT’s existing p-series, offering a similar “Winglet” design that is optimised to offer maximum airflow and minimal drag, with a new fluid dynamic bearing for enhanced longevity. Below is a statement from Johnny Hou, the founder and CEO of NZXT.
 Pushing PC gaming to its limits is very important to us at NZXT
Whether you are overclocking the latest processors or running two GeForce GTX 1080 Ti graphic cards in SLI, products like Aer F are designed to maximise performance without being intrusive. Having a PC running cool and quiet makes for a deeper more immersive gaming experience.
Alongside these new fans, NZXT launched their new Aer Trim kits for their 120mm and 140mm Aer series fans, allowing users to customise the inner grey ring of their with red, blue and white options, allowing Aer fans to be coloured to better suit the user’s PC.
Aer F main features:
  • – PWM fan designed for better airflow and near-silent performance.
  • – Winglet constructed fan blades minimise drag, improving overall cooling.
  • – Patented fluid dynamic bearings (FDB) deliver long-lasting operation. (60,000 hours / 6 years)
  • – Sleeved cables for easy and clean cable management.
  • – Replaceable colour trim choices give builders the flexibility to customise their builds (sold separately)
NZXT’s new Aer series F120 and 1F140 fans will launch in April 2017 with the following prices and options.
MSRP Pricing:
– Aer F120 (Single Pack) – £19.99
– Aer F120 (Twin Pack) – £29.99
– Aer F140 (Single Pack) – £19.99
– Aer F140 (Twin Pack) – £32.99
– Aer Trims 120mm (Available in Red, White, and Blue) – £5.99  for two trims
– Aer Trims 140mm (Available in Red, White, and Blue) – £5.99  for two trims
You can join the discussion on NZXT’s new Aer f-series fans on the OC3D Forums.
