NZXT releases its Kraken X-3 and Z-3 series All-In-One Liquid Coolers
NZXT has released five new CPU coolers into its Kraken series of all-in-one (AIO) liquid coolers, shipping under the new Kraken X-3 and Z-3 naming scheme. These new liquid coolers are the Kraken X53, Kraken X63, Kraken X73, Kraken Z63 and Kraken Z73.
The most exciting of these new entries are NZXT’s new Kraken Z-3 series of liquid coolers, which feature a CAM-compatible LCD screen on its block/pump unit. This 24-bit screen is 2.36 inches (60mm) in size and can be used to display system information, animated GIFs or static images. The Kraken Z-3 series will release with 280mm (Z63) and 360mm (Z73) options.
NZXT’s X-3 series is more similar to the company’s older Kraken series coolers, offering users an LED ring that’s 10% larger than its predecessors and a new logo design which can be rotated to enable more cooler mounting options. This design tweak allows NZXT’s logo to be facing the correct direction regardless of how the cooler and its tubing is oriented. The X-3 series will be released in three forms, offering buyers 240mm (X53), 280mm (X63), and 360mm (X73) radiator size options.
NZXT’s Kraken X-3 and Z-3 series cooler are compatible with all modern mainstream CPU sockets from AMD and Intel, including AM4 and LGA 1151. Each of these coolers will also be shipped with NZXT’s Aer P Series (non-RGB) radiator fans.
In the US, NZXT’s new X-3 and Z-3 series of all-in-one liquid coolers are available starting today through the company’s webstore, with availability in the rest of the world starting in February.
Below are the US MSRP prices of NZXT’s latest all-in-one liquid coolers.
Kraken X-3 Series
– Kraken X53 (240mm AIO cooler): $129.99 USD
– Kraken X63 (280mm AIO cooler): $149.99 USD
– Kraken X73 (360mm AIO cooler): $179.99 USD
Kraken Z-3 Series
– Kraken Z63 (280mm AIO cooler): $249.99 USD
– Kraken Z73 (360mm AIO cooler) $279.99 USD
You can join the discussion on NZXT’s Kraken X-3 and Z-3 series of All-In-One Liquid Coolers on the OC3D Forums.
