NZXT Announces the S340 Color Edition Chassis
PRESS RELEASE
NZXT Source 340 - S340 Review
This Fall saw the S340 lead the way for NZXT in the entry-level case category, bringing premium quality and innovative design to the sub $70 space. Today we're pleased to announce the availability of the S340 in two new stylish colors: Matte Black paneling with either Gloss Blue or Gloss Red accents. Both colors will be widely available to all NZXT sales partners.
Forged from strong, cold-rolled steel, the S340 exudes an air of confidence that only the most durable of cases is capable of exhibiting. Axing the optical bays and relocating the HDDs to a lower position opens the case up like never before, making this one of the easiest cases to build in ever. A grommet-less cable management solution, alongside over twenty zip-tie locations and plenty of space behind the motherboard tray gives you unprecedented cable management options for a mid tower case.
When it comes to keeping cool, the Source 340 is no slouch. With Kraken X61 compatibility in the front intake, X31 compatibility in the rear exhaust, and a total of up to three 140mm or for 120mm fans you have plenty of cooling options. Thick front panel cutouts allow unrestricted airflow to reach our fully filtered intake. The Source 340 comes with the standard accouterments that you would expect from a premium case, such as USB 3.0, filtered intakes, a PSU shroud, and quality materials. Easily one of the most durable cases we've ever made, the Source 340 boasts 360 degrees of steel casing, extremely minimal plastic use, and extra thick side panels.
 NZXT Announces the S340 Color Edition Chassis  NZXT Announces the S340 Color Edition Chassis
The S340 is everything a new builder, an experienced modder, or any PC enthusiast needs. The S340 Color Edition will be available in Europe soon for just €69.99.
Join the discussion on the new Source 340 colour options on the OC3D Forums,
«Prev 1 Next»
01-01-2015, 05:35:02
Thelosouvlakia
I'm slowly starting to get convinced swapping the 750D with the S340 for my summer build *_*Quote
01-01-2015, 06:18:28
voodoografix
I have looked at this too with some interest , I recently built a rig for my son using the H440 I was impressed with the build quality . And if the Source 340 is as good then I think this with be replacing the case I currently use as my home server .Quote
01-01-2015, 06:48:10
Sp33d Junki3
I own the white S340. Build is not bad, but airflow is best I've seen with 2x 140mm front intakes.
I do like the red and blue versions. Very subtle.
H440 is still good, S340 is smaller.Quote
01-01-2015, 07:50:20
TPC
Do I want to give up my nightstand for this? I don't know! maybe a second build?Quote
02-01-2015, 10:01:23
met
It looks like the h440. For 70 euro probably will be one of the best-buy cases for this money rangeQuote
