NZXT announces their new Aer series of RGB Fans
NZXT announces their new Aer series of RGB Fans, which offer full NZXT HUE+ compatibility and NZXT CAM software control, allowing users to sync your fan lighting with your existing NZXT RGB setup.
These new RGB fans will come in both 120mm and 140mm versions with their NZXT HUE+ controller being able to control up to 5 fans separately. These fans will have 10 built in lighting modes and a wide array of colour options, allowing you to create some fancy lighting setups with this fans 8 built-in RGB LEDs.
      NZXT announces their new Aer series of RGB Fans  NZXT announces their new Aer series of RGB Fans
These fans will come with fluid dynamic bearings and NZXT's new enhanced winglet fan tips, allowing these fans to offer enhanced performance and lower noise levels than NZXT's older fans. NZXT's new Aer series of fans will also be 4-pin PWM controlled, allowing users to adjust these fans to the exact speed and noise level that they desire.
These fans will run between 500 and 1500 RPM and will be available in both single and triple packs, with a two Aer fan bundle coming with an NZXT HUE+ controller. All of these bundle options will be available for both 120mm and 140mm variants.
You can view a selection of NZXT's HUE+ Aer Fan colours and modes on their dedicated Aer RGB webpage. At this time we have no official word on pricing and availability.
You can join the discussion on the NZXT Aer series of RGB LED fans on the OC3D Forums
«Prev 1 Next»
13-09-2016, 13:30:29
Surpuppa
This looks so much better that light up fan blades imo. Although I do not like the non circular design. Thermaltake riing fans are perfect, I do not buy from them though...Quote
13-09-2016, 13:35:05
Greenback
I think the corsair HD are the better ones of the RGB fan's I've seen so far, I like the blade lighting up but not from the inside outQuote
13-09-2016, 13:41:08
NeverBackDown
I'll wait till a video review or something to get a better feel of them. Don't think pictures will capture it wellQuote
13-09-2016, 13:53:19
RickPlaysWarr
Nope, I am not on the current bandwagon of RGB whatever. I think they look ugly. I much prefer the Corsair ML series of fans. I like subtle lighting, preferably white and not a garish display inside the case.
--Rick--Quote
13-09-2016, 18:11:04
jimma47
Agreed - the Riing fans look great visually.Quote
