NZXT Refreshes its Kraken Series of Liquid Coolers with New White Models
Following the reveal of their new H510 Flow enclosure, NZXT has announced new entries to their Kraken lineup of All-in-One (AIO) liquid coolers, adding new white models to their product stack alongside a new ARGB illuminated 120mm model.
With Black and White case options being standard throughout NZXT’s product stack, offering users a white version of their Closed-loop Liquid Coolers (CLCs) is a logical step forward for the company, giving their customers more options for PC customisation. This is especially true for fans of RGB lighting, as white components react to nearby RGB lights much better than their black equivalents.
These new components are now available to pre-order in the UK through Scan, with NZXT expecting orders to ship in early-mid October.
    NZXT announces the latest Kraken X, Kraken Z, and AER RGB 2 fans —in a sleek matte white.
NZXT is taking the challenge out of achieving an all-white build. This family of white cooling products came directly from community feedback, allowing users to express themselves by giving them more options for the ideal build.
Find a fresh take of the Kraken Z, X, Kraken 120, and AER fans.
The Kraken 120 has received some upgrades from previous models. It features an improved pump with a larger water reservoir, a refreshed look, and support for 5V ARGB ecosystems.
NZXT Refreshes its Kraken Series of Liquid Coolers with New White Models Like NZXT’s other Kraken series liquid coolers, these new models can be controlled using NZXT’s CAM software utility, which can be used to monitor the performance of your cooling solution, adjust your system’s RGB lighting and keep track of other important data.
These new white Kraken models are the same as their black counterparts. Only their colours have changed, which means that reviews for NZXT’s older units should apply to these new variants. NZXT uses the same pumps, fans and RGB lighting with their new White series coolers.
NZXT’s new Kracken 120 is a compact 120mm liquid cooling solution that features several upgrades over NZXT’s older 120mm model. Their new unit includes an upgraded pump, a larger reservoir, an updated look and support for 5V ARGB product ecosystems.
    What’s new?
–  A minimalistic white colour option
–  RGB options for the matte black Kraken Z series
The same great features:
–  Seamless management by CAM, our performance monitoring application
–  Winglet-tip fan blades for fast and quiet operation
–  Fluid dynamic bearings provide long-term reliability and powerful cooling performance, rated for 60k hours.
MSRP Pricing
Kraken X-3 RGB Series White:
– Kraken X53 RGB 240 mm AIO: £159.99, $159.99
– Kraken X63 RGB 280 mm AIO: £174.99, $179.99
– Kraken X73 RGB 360 mm AIO: £199.99, $219.99
Kraken Z-3 RGB White:
Kraken Z53 RGB 240 mm AIO: £229.99, $249.99
Kraken Z63 RGB 280 mm AIO: £239.99, $269.99
Kraken Z73 RGB 360 mm AIO: £259.99, $299.99
Kraken 120 (Matte Black)
Kraken 120: £74.99, $79.99
NZXT’s new white AIOs are now available to pre-order in the UK through Scan, with NZXT expecting orders to ship in early-mid October.
You can join the discussion on NZXT’s refreshed Kraken liquid cooling lineup on the OC3D Forums.Â
