NZXT show off their S340 Chassis
NZXT S340 Chassis
Published: 2nd September 2014 | Source: NZXT |
NZXT are one of OC3D's favourate case makers, with their H440 being the only case to ever be given TinyTomLogan's prestigious White Gold Award. Now NZXT has revealed their S340, a similar more budget friendly design which also removes optical bays.
Lets have a look at NZXT's teaser;
When it comes to keeping cool, the Source 340 is no slouch. With Kraken X61 compatibility in the front intake, X31 compatibility in the rear exhaust, and a total of up to three 140mm or for 120mm fans you have plenty of options when it comes to keeping your components cool.
Thick front panel cutouts allow airflow to reach our fully filtered intake. The Source 340 comes with the standard accouterments that you would expect from a premium case, such as USB 3.0, filtered intakes, a PSU shroud, and quality materials. Easily one of the most durable cases we’ve ever made, the Source 340 boasts 360 degrees of steel casing, extremely minimal plastic use, and extra thick side panels.
Pricing and Availability
This case is currently available for preorder from NZXT's website, but is expected to be available in the coming weeks for the price of $69.99 USD.
Join the Discussion on the NZXT S340 on the OC3D Forums.
JRQuote
Should really be in news though
Edit:
Read more on the NZXT S340 Chassis here.Quote
