Parvum X1.0 ITX Chassis
The X1.0 Chassis from Parvum Systems
Parvuum X1.0 ITX Chassis
Parvum's latest upcoming chassis has been shown online and it looks great. The Parvum chassis is called the X1.0 and is ITX ready, perfect for building a high quality build in small spaces. We are sure the X1.0 will be a fantastic case if the 2.0 chassis is anything to go by.
The Parvum X1.0 chassis is built from high quality acrylic and comes in the same flat pack style as before, meaning you will need to build the case first, before you can insert any of your hardware.
The dimensions of this case are 250mm (W) x 244mm (H) x 310mm (D) and offers a maximum CPU cooler height of 150mm. The X1.0 supports two 2.5" drives and has the cooling abilities of one 120mm front intake fan which will be included, and one 80mm rear fan which won't be included, although we are not really supporters of 80mm fans as they need to move much faster to move the air and thus typically create much more noise. We did notice an SFX PSU mount which will limit your possible PSU choices though but this does help keep the overall size of the case down.
The X1.0 comes in the following colours.
  • Black and Red
  • Black and Blue
  • Black and White or reversed around in White and Black.
Parvuum X1.0 ITX Chassis  Parvuum X1.0 ITX Chassis  Parvuum X1.0 ITX Chassis  Parvuum X1.0 ITX Chassis
What are your thoughts on Parvum Systems X1.0 chassis? Can you see yourself using it in an upcoming build, or maybe changing your current ITX case in exchange for the X1.0, let us know on the OC3D Forums.
«Prev 1 Next»
26-01-2015, 18:29:59
Davva2004
Link appears to be broken?Quote
26-01-2015, 19:41:14
Feronix
Good shout, fixed
Interesting case, but probably more expensive and less efficient than my Phenom, albeit a lot smaller.Quote
