Paste the Magic - NZXT launches High-performance Thermal Paste
Get thermal conductivity, easy application, and long-term stability - all in a pea-sized drop.
Published: 22nd June 2022 | Source: NZXT |
NZXT has entered the thermal paste market
NZXT has officially entered the thermal paste market, offering customers 3g and 15g tubes of "high-performance" thermal paste for prices of $9.99 and $19.99 respectively.
NZXT's new High-Performance thermal paste ships with a thermal conductivity of 6.3 W/m-k, and claims to be non-conductive, making the thermal compound safe to used on PC without any additional precautions. NZXT's bundling their thermal paste with an alcohol wipe to enable easy application, and gives each tube of thermal past a shelf life of three years.
Below are the specifications of NZXT's new thermal compound.
NZXT Thermal Paste Tech Specs
Tube Sizes: 3g and 15g
Material(s): Zinc oxide, Liquid polymer, and Aluminium
Thermal Conductivity: 6.3 W/m-k
Viscosity: 35~220*10³ mPa.s
Specific Gravity: 3.5 g/cc
Electrically Conductive: No
Shelf life: 3 years
You can join the discussion on NZXT's high performance thermal paste on the OC3D Forums.
