Phanteks announce their new GTX 1080 Ti Founders Edition water block
Phanteks has announced their new GTX 1080 Ti Founders Edition water block, which will release in April and cost £129.99 in the UK.
This new water block is designed to support both Nvidia’s GTX Titan X Pascal and GTX 1080 Ti, allowing both of these GPUs to be water cooled with ease and potentially allowing higher stable overclocks and higher sustained boost clock speeds.
This water block will support RGB illumination, with LEDs built into the water block itself, with the ability to control these LEDs using a Phanteks RGB case or using a 4-pin RGB motherboard header.
These new water blocks will release in early April and will cost £129.99 in the UK and €149.90 in the EU.
You can join the discussion on Phanteks’ GTX 1080 Ti water block on the OC3D Forums.
