Phanteks goes Matrix-crazy at CES 2026
Phanteks unveils its “Matrix Series” with two new PC case options
Phanteks has launched its new Matrix Series of PC cases at CES 2026, bringing intelligent LED displays to its premium case models to give them some extra flair. The Nexlinq App will power these new Matrix displays, delivering real-time control with a minimal performance cost. Phanteks claims that the app will use less than 3% of CPU resources at all times.
Two Matrix series case models were unveiled at CES 2026. The first is the Evolv X2 Matrix, a new variant of the Evolv Series X2 (which we reviewed here). This case will feature a 900-LED matrix display. The Evolv X2 Matrix will be priced at £179.90/$199.99/€199.90 and available in Charcoal Black and Grey White.
Evolv X2 Matrix Key Features:
- 900-LED Matrix Display hidden behind premium fabric, powered via one SATA cable plus a USB 2.0 header
- All animations and stats run smoothly through Nexlinq, which operates on less than ~3% of CPU resources in all conditions
- Woven fabric covering provides soft, refined illumination while maintaining a clean, minimalist look
- Vertical cooling with bottom-to-top airflow
- Integrated D-RGB accents and clean cable management
- ATX rear-connector mainboard support
XT View Matrix
Next, we have the XT View Matrix, a new, upgraded version of the XT View. It now has a 600-LED Matrix display that’s hidden behind a woven fabric layer. This gives the Matrix display an appealing, albeit stylised look. The XT View Matrix will be priced at £104.90/$119.99/€119.90 and available in Charcoal Black and Grey White.
XT View Matrix Key Features:
- 600-LED Matrix Display hidden behind soft fabric, powered via one SATA cable plus a USB 2.0 header
- Powered by Nexlinq, the display remains responsive without impacting performance, drawing less than ~3% CPU
- Support for large GPUs and rear-connector mainboards
- Up to 9x 120 mm fan positions with top radiator support
- 3x M25-120 mm D-RGB fans included
Matrix Upgrades incoming
A new Matrix-600 is coming for Phanteks’ XT View and G400A PC cases. This provides existing owners of Phanteks’ cases the ability to upgrade their systems with a LED matrix display without full case swap-outs. Note that this upgrade kit will cost £43.90/$49.99/€49.90 and available in Charcoal Black and Grey White.
You can join the discussion on Phanteks’ newest PC cases on the OC3D Forums.
