Phanteks Announces Enthoo Mini XL Chassis
PRESS RELEASE
Phanteks announce the release of the Enthoo Mini XL, a super micro ATX. The Mini XL has been redesigned with optimal cooling in mind. Resembling the Enthoo Primo, it offers extensive water-cooling possibilities.
The Enthoo Mini XL, a compact and powerful structure with a sandblasted aluminum faceplates with matte finish. The Mini XL introduces a new form factor, super micro ATX. Unlike the Enthoo Primo, the Mini XL comes with a new RGB LED light system with mulitcolor control (10 colors) and supports dual motherboard configuration with the Mini XL ITX upgrade kit (PH-ITXKT_01).
Phanteks Announces Enthoo Mini XL Chassis  Phanteks Announces Enthoo Mini XL Chassis  Phanteks Announces Enthoo Mini XL Chassis
With the Enthoo Mini XL, the main challenges was to make effective use of space through design. The Mini XL's power supply location is now on the top back side of the case for optimal cooling. The Enthoo Mini XL comes with many features like dual removable hard drive cages, Drop-NLock SSD Brackets, quick eject dustfilters, LED control, mod friendly structure, and easy cable management.
The Mini XL also offers extensive water and air cooling. Convenient pump bracket with preinstalled vibration dampeners, PWM control hub allows for up to 7 fans to be controlled by PWM, 2 reservoir mounting locations, radiator side bracket, and dual rear fan exhaust.
For the one who desire even more, the Mini XL leaves options for additional upgrades. Extra upgrades like internal ambient lighting sytem (PH-LEDKT_M1/ PH-LEDKT_M2) that matches with the exterior ligthing, 2 extra slots for SSD Brackets (PH-SDBKT_01), 2 locations for HDD upgrade with Phanteks HDD Bracket (PH-HDDKT_01), and dual motherboard using our upgrade kit (PH-ITXKT_01).
"Features such as being very versatile, having a spacious and clean interior and of course making it very easy to build water-cooling systems is what the Enthoo Series is all about," says Boon, Designer of the Enthoo Series.
The recommended retail price is
  • PH-ES414M_BK : $179.99
  • PH-ITXKT_01 : $29.99
  • PH-HDDKT_01 : $7.99
Join the discussion on the Phanteks Entho Mini XL Case on the OC3D Forums.
«Prev 1 Next»
05-01-2015, 04:52:03
barnsley
I have a mATX based PC. And a Mini ITX PC. Its a shame that the cable management doesn't look great (from the review I saw of it).
Tempting.Quote
05-01-2015, 06:47:35
ermacos
I like phanteks cases from the reviews I ve seen, but the problem with Phanteks, it is not supported by many countries including mine. So, only few stores import some phanteks cases from abroad, in big prices... lol
That said, I always end up with coolermaster cases. Amazon used to support my country for super free saver delivary option, until recently that changed. So no phanteks for us (you pay allot now for a 10-15-20klg post fees)Quote
05-01-2015, 08:26:48
Wargod56
Really liked the look of this in a preview, only thing I dont like is the placement for the SFX PSU, makes me wonder if you could split a 24 pin into 2 if you have 2 systems and only use one PSU for a really clean look, seems doable considerring you can get single PSU's in 1500W variants,Quote
05-01-2015, 11:00:13
Permafrost
Phanteks needs to make a bayless Enthoo Primo and just slap a massive rad mounting system there, i'm busting my ass off trying to save up and find work doing anything to get my hands on a caselabs.....
still no luck with work...Quote
05-01-2015, 14:55:12
The_Governour
I still want to see a True mini itx chasis from Phanteks.
https://www.youtube.com/watch?v=r1nPVLuWFNoQuote
