Phanteks Announces Enthoo Pro M Acrylic Window Edition Chassis
Phanteks Announces Enthoo Pro M Acrylic Window Edition Chassis - PR
Phanteks today announce the release of the Enthoo PRO M Acrylic Window Edition. Phanteks' new Enthoo Pro M variant will now include a full acrylic side panel. The Enthoo Pro M Acrylic Window Edition will include features like the new HDD mounting system, PWM hub, the innovative radiator bracket and pump mounting locations. System builders and watercooling enthusiasts can now showcaase their build.
The PRO M Acryclic Window Edition has a full acrylic window, front and top brushed aluminum look panels, and the innovative radiator bracket. The I/O port now resides on the side of the front panel creating a simple but elegant design without the cost. The PRO M Acrylic Window Edition will feature a large interior to support full ATX. A innovative top radiator bracket to allow easy installation of the radiator and/or fans like the Enthoo EVOLV ATX and the EVOLV ITX.
 Phanteks Announces Enthoo Pro M Acrylic Window Edition Chassis  Phanteks Announces Enthoo Pro M Acrylic Window Edition Chassis
The PRO M Acrylic Window Edition comes with the all new HDD mounting system that can support multiple storage with the optional HDD bracket (PH-HDDKT_02).
The PRO M Acrylic Window Edition is designed with watercooling in mind. Multiple reservoir and pump mounting locations, as well as storage capacity are all possible with the upgrade options. With the full acrylic side panel, all your components will be visible.
"Being very versatile, having a spacious and clean interior and of course making it very easy to build water-cooling systems is what the Enthoo Series is all about." - Boon Tuoh Khor.
Available at most local retailers in December, 2015, the recommended retail price is €89,90 / £69.99 (VAT Included).
The case is currently available for Pre-order at Overclockers UK for the price of £69.99
My Thoughts
It is great to see that Phanteks are doing more with this case revision than just adding a new Windowed side panel, this case uses a new HDD mounting system, includes Phanteks' new fan hub and has a new way to mount the top radiator to the chassis.
The new window design is something that we would be more familiar with with more expensive InWin cases, with the cases covering the whole side panel area but instead of using Plate glass Phanteks has used a less expensive Acrylic panel, which explains this cases price of only £69.99.
Hopefully we will be seeing a new version of Phanteks' lineup pf cases including this new window design in the near future, as it is always great to see a little bit more variety in modern case design.
You can join the discussion on the Phanteks Enthoo Pro M Acrylic Window Edition on the OC3D Forums
«Prev 1 Next»
15-12-2015, 07:52:04
Davva2004
I like it at lot, but I'd like it more if the PSU cover was solid throughout and didn't have the drop and lock mounts on it.Quote
15-12-2015, 09:49:42
dwatterworth
Phanteks construction quality is so sexy that I'd buy that thing with acrylic across all faces! Now to find someone with a desktop CNC for some custom aluminum panels...Quote
15-12-2015, 15:37:45
Lystfiskern
Finally... I thought. A case that could put my aging Fractal Design Arc Mini R2 to rest.... but wait....M ? ....what M? There`s a full 7 pcie-slots available on there?
Crap....well nevermind. Hopefully Fractal has a new Define Mini just around the corner.
BTW. Real nice case tho. Think Phanteks has done brilliant in the case game thus far.Quote
15-12-2015, 16:33:04
jimma47
Phanteks are just going from strength to strength. Some of their aesthetics are a bit of a take it or leave it style but overall really impressed.Quote
