Phanteks Announces the EVOLV ATX Tempered Glass Edition Chassis
Phanteks has announced a new version of their EVOLV ATX case, this time with Tempered Glass side panels and a full window, which allows users to show off every inch of your PC, including your cable management.
The Evolve ATX Tempered Glass will support 10 colour RGB LED lighting, allowing you to cycle the cases included LED colours or combine it with your existing case lighting system.
  Phanteks Announces the EVOLV ATX Tempered Glass Edition Chassis  Phanteks Announces the EVOLV ATX Tempered Glass Edition Chassis
The Evolve ATX is a case that is designed for heavy water cooling and to deliver a premium aesthetic. The case comes with 3 Phanteks PH-F140 fans at stock, two SSD brackets, 3 modular HDD brackets, a retractable top radiator mount and several removable dust filters.
  The next evolution - The Phanteks Enthoo Evolv ATX Glass does away with the norm when it comes to side panels and replaces the entirety of both sides with a beautiful and classy tempered full-glass window. This is the ultimate full aluminium case to show off every inch of your custom build, including your pristine cable management skills!
The Evolv ATX Glass is available for pre-order in three different finishes - Black, Silver, and Gun Metal. This allows you to choose a Phanteks Evolv Glass to perfectly suit your gaming PC system!
Right now the Phantek's Evolv ATX Tempered Glass edition case is available for Pre-Order at Overclockers UK for the price of £154.99.
This case will be releasing in Early April and is expected to cost €189.90 in the EU.
You can join the discussion on Phanteks' new Evolv ATX Tempered Edition Glass PC case on the OC3D Forums
«Prev 1 Next»
29-04-2016, 16:48:27
steverebo
I don't like the idea of a window on both sides makes cable tidying even more hard work to keep it looking smart. Other than that I quiet like this case the sliding out Rad mount is a great IdeaQuote
29-04-2016, 17:08:15
WYP
I see the glass on both sides as a challenge to try your best with cable management.Quote
29-04-2016, 17:19:20
steverebo
True although you would have to opt for something a little more classy than cable ties maybe some nice branded Velcro ties.
I guess I'm just used to cable tidying as best I can and then hiding it behind the side panel normally having to sit on it to get it closed Quote
29-04-2016, 17:43:38
jimma47
Hope they do the silver version. This looks amazing.
I agree on the cable challenges for the back side being glass. Much like the 805 in that regards. I think some strategic use of Velcro, cable ties and maybe some internal panels/covers similar to the HexGear R40 would go a long way sorting that out.
It almost needs a false floor under the motherboard tray to channel most of your cables through and then mount some SSD's just under the glass. Not sure how much room is at the back tho!Quote
29-04-2016, 18:44:00
Wraith
If I were to go for a case such as this or inwin equivalent, I'd 100% have to make my own cables, alternatively get Pexon or cablemods to make some up.Quote
