Phanteks New MP Series Fans
PRESS RELEASE
Phanteks, the award winning designer of the Enthoo Primo, today announced the immediate availability of the PH-F120MP and PHF140MP Series High Static Pressure fans. The new MP Series fans are designed specifically for radiators. They have the ability to overcome the airflow restriction caused by high fin density from radiators. They will be available in 120mm and 140mm sizes.
The MP Series High Static Pressure fans are equipped with a new seven blade design that can produces high static air pressure allowing for a direct and focused airflow making them ideal for the densely packed fins of a radiator. The MP Series fans delivers an outstandingly low vibration, noise and turbulence with the eight preinstalled acoustic dampers.
Phanteks New MP Series Fans  Phanteks New MP Series Fans
The new redeveloped blades in MP Series are bigger and designed to achieve higher air pressure. The redesigned MVB II blades generate better airflow and produces better performance. It improves the balance of airflow and air pressure when using with as a cooler fan or case fan.
MP Series' PWM functions allow users to adjust speed from 500 - 1600 RPM on the PH-F140MP and 500 - 1800 RPM on the PH-F120MP. Higher speed for performance and lower for silent operation.
Phanteks products are made to the highest standards and should provide many years of excellent service. Providing you with the best customer care, Phanteks are offering a 5 year warranty.
Join the discussion on Phanteks MP series fans on the OC3D Forums.
«Prev 1 Next»
27-10-2014, 15:05:40
Tripp
I look forward to seeing how these performQuote
27-10-2014, 20:02:03
Kushiro
haha these came just on time, though will there be a LED variant? As I am thinking of getting 3 of these PH-F140SP, but would be more than happy to wait for these new ones.Quote
