Phanteks Release their Enthoo Pro M Full Acrylic Window Edition
Phanteks has released their new Enthoo Pro M Full Acrylic Window Edition chassis, offering heavy water cooling support for a very reasonable price.
This new chassis will be available in Titanium Green, Anthracite Gray and standard black, with all colour options already being available to Pre-order at Overclockers UK.
The Enthoo Pro M remains largely unchanged, offering the same water cooling support and the same innovative "easy install" top radiator mounting bracket. This case comes with a 5-year warranty and will be available to purchase this month
FEATURES
- Brushed aluminum look
- Clean interior - Hidden PSU and HDD’s
- Optimal airflow - Direct airflow to CPU / GPU
- Comes with 2 Phanteks premium fans - 1x PH-F140SP in front/rear (140mm)
- 3 different installation areas for radiators (120mm or 140mm form factor).
- Reservoir mounting locations
- 1x Drop-N-Lock SSD brackets included
- Removable HDD cage for installation of long PSU’s (>180mm) / waterpump
- Equipped with removable dustfilters (1x front, 1x bottom, 1x top magnetic)
- Clean cable management using Phanteks' preinstalled Hoop-N-Loop cable ties
- Removable optical drive cage
Phanteks Release their Enthoo Pro M Full Acrylic Window Edition  Phanteks Release their Enthoo Pro M Full Acrylic Window Edition
SPECIFICATIONS
- Dimension: 235 mm x 480 mm x 500 mm (W x H x D), 9.25 in x 18.9 in x 19.7 in
- Colour: Black
- Form Factor: Midtower Chassis
- Material(s): Plastic Exterior, Steel Chassis, Acrylic Side Window
- Motherboard Support: E-ATX *(up to 264mm wide), ATX, Micro ATX, Mini ITX
- Front I/O: 2x USB 3.0, Mic, Headphone, Reset
- Side Window: Yes
- Expansion slots: 7
- Internal 3.5": 8x (2x included)
- Internal 2.5" (dedicated): 3x (1x included)
- Cooling: 120mm Fan - Front: 2x (3x without ODD Cage), Top: 3x, Rear: 1x
- Cooling: 140mm Fan - Front 2x (1 included), Top: 2x, Rear: 1x (1 included)
- Liquid Cooling: 120mm Radiator - Front: Up to 360mm, Top: Up to 360mm, Rear: 120mm
- Liquid Cooling: 140mm Radiator - Front: Up to 280mm, Top, Up to 280mm, Rear: 140mm
- Graphic card Clearance: 420 mm (16.54 in) No HDD brackets, 300 mm (11.8 in) HDD brackets installed
- PSU Clearance: 318 mm (12.5 in)
- CPU cooler Clearance: 194 mm (7.6 in)
- Cable management: 35 mm (1.38 in)
- Memory clearance (motherboard - fan): 120mm: 68 mm (2.68 in), 140mm: 48 mm (1.89 in)
- Package Dimension: 315 mm x 545 mm x 585 mm (WxHxD)
- Net Weight: 7.4 kg (15.4 lbs)
- Gross Weight: 9.0 kg (19.8 lbs)
- Warranty: 5 Years
The Phanteks Enthoo Pro M is currently available to Pre-order for the highly affordable price of £69.99 at Overclockers UK
You can join the discussion on the Phantek's Enthoo Pro M Full Acrylic Window Edition chassis on the OC3D Forums.
«Prev 1 Next»
10-05-2016, 07:29:21
Kushiro
If only the whole front panel was like the other 80%Quote
10-05-2016, 13:55:45
RobM
This was released earlier in the year, I have been using mine since February the recent release is for the grey and green colours. I really love mine even the front panel lol :PQuote
10-05-2016, 17:39:05
Thelosouvlakia
Phanteks' enthoo lineup is more like "workstation oriented" There are people who still only use optical media. For example where security is really important, you can't trust any USB drive it may fry your motherboard. A CD is harmless could only contain a virus and should ask for admin/root/sudo priviledges to run and damage something.Quote
10-05-2016, 18:55:22
jimma47
I'd agree it would look better without it but yes there's still a large population without fast, affordable internet and/or other reasons to use ODDs or bays.
Having said this, and with the removable cage in mind they could have used mesh the whole way. One large bit for the front fan intake and then two pop out sections for the ODD and the space between. At least then they could all be used as intake, or as 5.25s or left as they are. Choice is good but hey it's not an expensive case and it still looks alright
Loving the windows I wish mine had one, or I had the skills and resources to do it.
They really should have community workshops or something but no doubt people would steal all the tools and leave the place a mess. If they can't rack weights what are the chances of putting tools back where they belong!Quote
